Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Vent pipe leak
Old 03-18-2013, 08:50 PM   #1
holowa1
Likes Given: 3
Default Vent pipe leak
I need help with a leak dripping into my basement from a vent pipe.
Here are the facts:
1. house built 3 years ago
2. vent services kitchen & laundry rooms.
3. I have cut an access hole behind my dryer in my laundry room and found the leak. (see pic)
4. Large picture is from the kitchen side during construction (drywall hiding it now)
5. In the small picture there is a slow dripping of water coming down the pipe at the arrow.
6. I have gone into the attic and everything is dry above the ceiling.
ANY IDEAS WOULD BE APPRECIATED
holowa1 is offline
Old 03-18-2013, 09:36 PM   #2
stevep
Sounds like a pipe wasn't glued or text tee plug is not tight
stevep is offline
holowa1 Likes This
Old 03-19-2013, 12:00 AM   #3
Liked 384 Times on 324 Posts
Likes Given: 549
Is that your dryer vent right beside it? If it is, have you cleaned the dryer vent pipe out?
holowa1 Likes This
Old 03-19-2013, 08:29 AM   #4
jdc
Plumbing Technologist
jdc's Avatar
Liked 4 Times on 3 Posts
Likes Given: 2
The first thing you're going to have to do is determine exactly where the leak originates. This is going to require you to remove more drywall. I'd do it from the laundry room side of the wall. You know the pipe is dry in the attic but water is pooling around the top of the tee and running down into the basement. There is your area of concern. Remove the drywall, find the source and you're nearly there. From looking at the setup, my first guess is that a screw was put into the pipe and over the past 3 years has rusted out. However, without opening things up and getting your hands and eyes on the source, its hard to tell.
Good luck
jdc is offline
holowa1 Likes This
Old 03-20-2013, 02:28 PM   #5
holowa1
Likes Given: 3
Just finish my exploration & fix.
It was the bottom of a tee where two vents came together.
(see picture)
I couldn't separate the joint, so I epoxied inside and out.
Leak has stopped and I hope it will hold.
Thanks for the feedback.
holowa1 is offline
Old 03-20-2013, 04:48 PM   #6
Likes Given: 218
That may hold but from the looks of the joints they didn't use primer on any of them. The primer will have a purple color so inspectors can see it has been used. If primer isn't used the joints won't seal properly.
Old 03-24-2013, 11:09 AM   #7
stevep
Lack of primer can definetly cause pipe to fail.primer has been required for years.might be something in the term solvent weld.But being a commercial plumber maybe we just try to do it right the first time
stevep is offline
Old 03-24-2013, 12:03 PM   #8
Likes Given: 218
You don't have to be a commercial plumber to do things right you have to know your trade and take enough pride in your work to do it right.
IFIXH20 Likes This
Old 03-24-2013, 05:00 PM   #9
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
Exactly, I'm a commercial plumber too but I've done residential service as well and the reason people cut corners is cause there lazy, don't care or don't know. Nothing worse than having to fix someone's poor decisions years later.
Old 03-24-2013, 05:05 PM   #10
Likes Given: 549
The question I have is how water is getting to the dry section of the vent pipe. Rain water maybe, but even dry fit wouldn't be too likely to leak on a vent.
Leak under Air Conditioning Vent Rangerpr General Plumbing Help 3 10-14-2012 03:30 PM
Studor vent on vent pipe above roof gquayle General Plumbing Help 4 09-13-2012 02:23 PM
How do I cut attic vent PVC pipe? mtv General Plumbing Help 2 11-19-2011 05:04 PM
Vent Pipe Configuration Centuriondk General Plumbing Help 13 06-05-2011 06:44 PM
Poorly placed vent pipe cookingterm General Plumbing Help 4 03-05-2010 11:16 PM
