Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Vent/Drain help
Old 11-18-2011, 05:40 AM   #1
staj
Default Vent/Drain help
I'm replacing the iron drain with PVC and rearranging a few things.
Can you provide some feedback on the attached two diagrams. My concern is the long horizontal vent run and the sink drain that wraps around and enters low. How do these look? Thank you for any input, appreciated.
staj is offline
Old 11-18-2011, 12:12 PM   #2
You can not have a horizontal below the flood rim of the highest fixture. Which in most cases is 42".
johnjh2o is online now
Old 11-18-2011, 01:51 PM   #3
staj
Thanks John-
Interesting, I heard that once before but just happened to forget it.
What I find perplexing, however, is that if I was to move the Water Closet to the left in the diagram all the way to the stack essentially, this would take care of the "horizontal vent" problem. For that reason, I don't get it.
I'm starting to think that I need a new stack in the house. Unfortunately, if I put it right above the sewer main, the stack would come out on the roof about 3.5 feet horizontally from a window and probably 3-5 feet below the highest point on the roof line (which I think violates UPC).
Any thoughts or advice would be appreciated.
Thanks again,
Greg
staj is offline
Old 11-18-2011, 01:55 PM   #4
staj
I should have said, "...,I think this would take care of the "horizontal vent" problem because that is how the existing set up is."
staj is offline
Old 11-19-2011, 05:06 AM   #5
staj
How does this look? Is the stack that is at about a 45 degree angle in the attic o.k.?
Thanks for the help.
Greg
staj is offline
Old 11-19-2011, 11:36 AM   #6
Your not quite there. You can't have a waste line connecting in between a toilet and it's vent. Connect the shower to the same line that serves the sink below the floor just be sure to increase the line to 2".
Drain/Vent Question mwb31 General Plumbing Help 6 04-29-2012 02:47 AM
Newbie With Sink and Toilet Drain Vent Questions kmoe General Plumbing Help 2 12-19-2011 04:32 PM
Drain and Vent Questions rsteve12 General Plumbing Help 21 09-24-2011 12:30 PM
Toilet drain and vent (seattle WA) otusweb Plumbing Building Code 6 06-04-2011 06:33 AM
can i reroute my shower drain and vent plumbing? jamesskim General Plumbing Help 1 11-17-2010 02:08 PM
