12-05-2012, 02:25 PM
Trap under tub?
Hi all...
I'm putting in a new tub and Looking at the plumbing below, there's a trap. Now I have to move the plumbing in 4 or 5 inches because of the configuration of the new tub. Now do I need a trap under my tub? The line Going up is the vent pipe.
Thanks,
Barry
12-05-2012, 07:38 PM
Liked 119 Times on 109 Posts Likes Given: 70
If you don't have a trap sewer gas will enter your home through the tub drain. That is the main reason for a trap. Many people mistakenly think there to catch objects that go down the drain.
12-05-2012, 08:00 PM
Yeah that's what I figured. Someone had told me that they had never seen a trap below a tub but everything I've read says that there should be, which makes sense.
12-06-2012, 02:11 AM
Liked 2 Times on 2 Posts
Whoever told you that has no knowledge of plumbing. All fixtures are trapped. Either there is an integrated trap built into the fixture (water closet, urinal, etc) or a trap is installed when the fixture is (sinks, showers, tubs, mop basins, etc).
12-06-2012, 03:15 AM
That's the reason for this forum. to help people that don't have knowledge of plumbing. I'm sure he could teach us a thing or two about his line of work. To each his own.
12-06-2012, 03:33 AM
Liked 60 Times on 53 Posts Likes Given: 15
Yeah agreed. Just cause we think its so simple doesn't mean everyone knows all about plumbing. When I started I didn't understand why there were p traps I just knew they were a part of the drain lol. Everyone has there thing like John said.
12-06-2012, 08:02 AM
Wow...didnt realize I'd get "corrected" for pointing out the obvious; that this guy's aquaintance had no idea what he was talking about. I thought I was rather polite, but I suppose I could have sugar coated it a bit. Sorry about that johnjh2o. Perhaps I'd better just stick to the other forums I'm a member of. Good day
12-06-2012, 11:25 AM
I wasn't correcting you, what you said about every fixture having a trap is correct. Sorry you took it the wrong way.
12-07-2012, 02:19 AM
One more question on this please... Do I need to move that trap exactly Underneath where the new tub drain is going? I have a new Kohler tub and the drain hole is some 4 inches further out and a couple inches to the right As you can see in the picture.
So I was curious if I could come down with the drainpipe a few inches, then 90 degree with an elbow and over to the trap. will that work?
12-07-2012, 02:32 AM
The tub drain needs to go directly into the trap. If not you a creating a running trap which is no legal.
