Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Toilet Vent and Wall Size
Old 05-18-2012, 01:53 AM   #1
rcspott
Default Toilet Vent and Wall Size
What size pipe does a toilet vent require and can a toilet be plumbed against a wall with 3.5" studs
Thanks
rcspott is offline
Old 05-18-2012, 06:23 PM   #2
desertwater
desertwater's Avatar
Toilet vent min. Is 2" however you need a full size cleanout before you can reduce to 2" if this is a second floor application you could flat vent a toilet with 2". cleanouts are not required on second floors (residential). and no 3" will not fit in 2 x 4 wall unless its steel stud.
desertwater is offline
Old 05-18-2012, 10:44 PM   #3
Liked 384 Times on 324 Posts
Likes Given: 550
That is very much dependant upon which code is in use in your area.
In my area, 1/2 the diameter the drainage pipe served, minimum drain for a toilet is 3", so 1 1/2", with at least one 2" diameter vent for each sewer connection.
phishfood is online now
Old 05-18-2012, 11:50 PM   #4
HoffmannFamilyPlumbing
Plumbing Expert
HoffmannFamilyPlumbing's Avatar
Depends which code your state adheres to. The International Plumbing Code (IPC) is 1 1/2" but the Uniform Plumbing Code (UPC) is 2"
http://hoffmanplumbing.net/
Hoffmann Family Plumbing
805-748-4324
HoffmannFamilyPlumbing is offline
Old 05-18-2012, 11:56 PM   #5
Likes Given: 218
3" pipe WILL fit in a 2x4 wall but the fittings will not. And you can not run a flat vent below the flood rim of the fixture unless it is washed by a fixture.
Old 05-19-2012, 01:52 PM   #6
desertwater
John, the toilet being flushed is washing the vent. no?
Old 05-19-2012, 03:06 PM   #7
Likes Given: 218
If the vent runs horizontal below the toilet there is no way that the toilet could wash it. There may be a small amount of water that will enter the vent but that is the problem. If the line is not being washed the vent could become plugged from waste being left behind in the vent. If the vent was being washed from above like in the case of a lav being armed off the vent it would be fine. No vent can be run horizontally unless it is 6" above the floor rim of the fixture.
Old 05-19-2012, 03:47 PM   #8
desertwater
This is how I see it.
Old 05-19-2012, 03:52 PM   #9
Likes Given: 218
The top one is wrong unless there is a fixture draining into the 2" vent above the toilet. The second on is correct you have no horizontal vent lines.
Old 05-19-2012, 03:55 PM   #10
desertwater
Ive done a lot of messed up plumbing then :/
Bathroom vent through wall? Dozey Plumbing Building Code 1 07-22-2011 12:31 PM
toilet vent running horizontal alainmax Plumbing Building Code 11 06-17-2011 06:05 PM
vent size tabrizi General Plumbing Help 0 11-08-2010 03:44 AM
Saniplus pumping toilet vent? dan0 General Plumbing Help 1 03-30-2010 02:00 PM
**Wall mount toilet for residetial** PAGEINC13 Toilets and Sinks 5 02-17-2010 03:01 PM
