Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Toilet problems
Old 12-26-2013, 06:38 PM   #1
SusaninTennessee
Likes Given: 2
Default Toilet problems
Last week, our toilet leaked from the bottom so husband replaced the wax ring. It helped at first, but today the leak is back. A little history: we're in a 40 year old house with original plumbing and have a septic tank. For a while now, we'd quite often have to use the plunger to get the toilet to empty. Does this mean there's a serious clog in the pipe? Would snaking help or do we need to call in a professional? Money is a concern so we'd like to take care of this ourselves if we can. Thanks for any help you all can offer.
SusaninTennessee is offline
Old 12-26-2013, 07:11 PM   #2
Zanne
Zanne's Avatar
Liked 67 Times on 63 Posts
Likes Given: 1135
Do you have any pictures of the toilet flange in its current condition?
Is the toilet steady or does it have some movement to it (does it rock back and forth or side to side when you sit on it and move around)?
How much water is leaking?
The flange could be damaged or there could be a crack in the toilet itself that is letting water out.
Did you check to make sure its from the actual base and not from the back of the toilet tank? I know it may seem silly to ask that, but toilets can leak from multiple places.
If you have to plunge your toilet frequently there might be a blockage either in the toilet or in the plumbing (I know, that is kind of obvious).
Do you ever smell sewer gas coming up from the toilet?
Zanne is offline
SusaninTennessee Likes This
Old 12-26-2013, 07:44 PM   #3
Likes Given: 219
If there is a stoppage in the line and the toilet floods the wax seal will leak. They can not seal against back pressure.
Old 12-26-2013, 08:24 PM   #4
SusaninTennessee
Likes Given: 2
Thanks for responding, Zanne and johnjh2o. The toilet doesn't move around and the water does appear to be coming from thwere the bottom meets the floor. When husband removed the tilet last week to replace the was ring, the wax ring was in pieces. So that does sound like maybe backflow? How do we correct that?
Old 12-27-2013, 01:45 AM   #5
Zanne
Zanne's Avatar
Likes Given: 1135
The backflow could be caused by a clog somewhere in the lines, improper incline/decline of the waste pipe, improper venting, and possibly the septic tank clogging.
I think the cleanouts for the plumbing for that area might need to be snaked. Your husband can do it himself when he lifts the toilet again to put on a new wax ring. Sometimes pouring white vinegar down can help.
Is it just the toilet or are you having any other plumbing problems?
*Gurgling in pipes when using the water or flushing the toilet
*Sewage smell coming from drains of other fixtures
*slow drainage of other fixtures
When was the last time you had your septic tank sucked out? If you recall, did you make sure that all of the waste was sucked out and not just the water (the guy I used to hire to drain mine would leave most of the solid waste and some of the water at the bottom every time-- he actually got fined by the dept of health for doing that on some jobs).
Do you flush tissues and "flushable wipes" down the toilet? I recommend NOT doing so as they don't decompose as well in septic tanks as regular toilet paper. Flushable wipes can get stuck in the pipes sometimes.
My best guess is that something is stuck in the drain for the toilet and needs to be dislodged with a snake.
Keep in mind that while any major work on the pipes in the house should be done by a licensed plumber, sewage sucking and such needs to be done by someone who is licensed for sewage. Generally your local Department of Health should have a list of people who are licensed in your area. They are not allowed to give you recommendations, but sometimes they can tell you which ones have had violations/fines.
Zanne is offline
Well problems nates90 Pumps and Wells 3 01-15-2013 11:56 PM
Toilet flush problems..........GRR! smitty81 Toilets and Sinks 6 04-29-2012 01:07 AM
Problems with venting??? christaylor General Plumbing Help 4 04-11-2012 05:52 PM
Kohler toilet problems bgreen Toilets and Sinks 8 10-09-2011 08:36 PM
Re-plumb - now problems ramilin General Plumbing Help 3 07-28-2010 03:09 AM
