Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Toilet flange height
Old 11-30-2012, 07:52 AM   #1
bggas400
Default Toilet flange height
Hello,
Remodeling upstairs bath and its been going on for the longest time. Anyway, as it stands, the toilet flange sits about 5/8" off the floor of which is 2 layers of 1/2" plywood. Now I'm going to put down 1/2" Durock, then 1/4" tile. My thought was to install the toilet on top of the tile. So is the height of flange sufficient as it will then be at least 1/4" below the finished floor or do I have to install the toilet before the tile?
Thanks for any help!
Barry
bggas400 is offline
Old 11-30-2012, 11:49 AM   #2
Liked 335 Times on 273 Posts
Where is the rest of the flange? Your missing the ring. As far as the height 1/4" below the finished floor will work you just need to DBL up the wax seal. Never tile around a toilet.
Old 11-30-2012, 12:33 PM   #3
Liked 416 Times on 347 Posts
Likes Given: 62
John, could you please go into a bit more detail regarding this?
Old 11-30-2012, 12:44 PM   #4
If you tile around a toilet and the wax seal fails the leak wouldn't show up. The water would become trapped under the toilet. Plus if the toilet ever needed to be replaced the foot print of the new toilet wouldn't match the old one. Because they change the design of bowls so often.
Old 11-30-2012, 01:13 PM   #5
Likes Given: 62
So essentially you are stating it is best to tile to the flange, not the specific toilet. I agree with you 100%.
I recently got a call from my G/F's son in law, who advised it appeared he had broken a water line under slab, because water was coming up from his linoleum around the bathroom perimeter. You guessed it, the linoleum was cut and caulked around the toilet and the wax ring failed. The water seeped under the tile for months unnoticed. I had to remove the entire linoleum after pulling the toilet, and saw the wax ring was shot. Once I replaced the floor up to the flange, and reset the toilet with a new wax ring, all is fine.
Old 11-30-2012, 02:27 PM   #6
What we do when setting a toilet on tile is calk the toilet down but not around the back side. This will allow the leak to become visible if the wax fails.
Drof65 Likes This
Old 11-30-2012, 03:05 PM   #7
bggas400
Thanks John! Never thought of that but it is quite logical. I do have the ring - somewhere I think - .
That piece allows for attaching the toilet to the flange, yes? That might also raise the total height of the flange.
bggas400 is offline
Old 11-30-2012, 05:35 PM   #8
Be sure you screw the ring to the floor on top of the tile.
Old 12-02-2012, 08:53 PM   #9
bggas400
Look like the ring will sit perfectly on top of the Durock. I can then tile right to the edge of the ring, yes?
bggas400 is offline
Old 12-02-2012, 09:42 PM   #10
You got it. Like I said before be sure to screw it down.
Toilet flange can I do this? Dogstar General Plumbing Help 1 04-20-2012 01:15 AM
Raise the toilet seat height idea. boytonstu Toilets and Sinks 3 08-30-2011 11:05 PM
Toilet instalation help - toilet rocks on flange beerdog Toilets and Sinks 3 04-17-2011 09:54 PM
Toilet water height problem Nathan Toilets and Sinks 1 01-19-2011 04:48 PM
Toilet Flange rmkcpa Toilets and Sinks 2 01-07-2010 02:31 PM
