Yes, you can use 2 wax rings. If you are not careful, though, the top rind can slip sideways off of the bottom ring, blocking the outlet of the toilet and causing a leak all at the same time.
When I have to double ring a toilet, I always put the first ring down on the flange, set the second one on top of it, then pinch the bottom of the top ring all the way around so that it "sticks" to the bottom ring, then set the bowl on top of that.
