Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Tapping into 3" drain pipe?
Old 06-21-2012, 09:03 PM   #1
Bogucki
Likes Given: 4
Default Tapping into 3" drain pipe?
Need to tap into 3" drain pipe from washer. This tap will drain two vanity sinks. Should I use a T fitting or a Saddle?
Im not sure I can squeeze the T fitting between the lines if I cut it.?. The line is about 15' long so I may have a little play between the two, but I'm not sure there is enough for a T.?. What is your experience with Saddles?
I thought about using alot of glue for the T, to keep it slick, and trying to do both ends at the same time. Slide one end all the way in, enough to get the other end into the T, then sliding it back over centering it between the two cuts. I was working with some 3/4" pvc yesterday for my hvac condensing line and I noticed that if I got a little sloppy with the glue, it was pretty easy to slide around for about 10 seconds.
Bogucki is offline
Old 06-22-2012, 01:23 AM   #2
Liked 385 Times on 325 Posts
Likes Given: 551
Don't use either a tee or a saddle fitting. Use a combination wye and 1/8th bend, and two banded repair couplings.
Old 06-22-2012, 04:40 AM   #3
Chris
Administrator
Liked 494 Times on 436 Posts
Likes Given: 42
Phish, what do you have against Saddle wye's? Out here that is what most all the cities and district require for lateral tie ins. I am just curious on why you don't like them.
Chris is offline
Old 06-22-2012, 06:11 AM   #4
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
SAddle....... Wye?? never saw one. I assumed the op was talking about a T saddle.
LiQuId is offline
Old 06-22-2012, 11:27 AM   #5
Likes Given: 219
They do make saddle Y's but I wouldn't use them inside a home. In fact I wouldn't use them outside. If you don't have the play in the line to cut a Y in then do as phishfood suggested.
http://stores.homestead.com/DrainageSolutionsInc/-strse-425/Flexible-Saddle-Wye-4%22/Detail.bok
Old 06-22-2012, 01:25 PM   #6
Bogucki
Likes Given: 4
Ah, I see. I've already pulled a few of those out on some of the old plumbing lines. I thought they were kind of cheap. If I cant get enough bend, I'll use em. Thanks, you guys ain't half bad.
Bogucki is offline
Old 06-22-2012, 03:59 PM   #7
Chris
Administrator
Likes Given: 42
We are required to use them all the time. they make them for Clay, PVC and out of rubber. I don't like the rubber ones.
Curious as to why you wouldn't use them outside?
The way we do it is cut out whatever needs to be cut out of the pipe, attach the saddle whether it be epoxy or those dumb band clamps and then we pour a concrete lug around it. It is the standard in most areas here in SoCal. Obviously we like to cut out a section of pipe and put a wye in and do it like we all think it is supposed to be but I am just curious as to what everyone has against the saddle wye.
Chris is offline
Old 06-22-2012, 04:23 PM   #8
Likes Given: 219
Cris I haven't seen this happen, but there made out of rubber and there is a possibility that when snaking the line it could you could punch a hole in it. Keep in mind that is just my opinion. I just tend to be more cautious then I should be.
Last edited by havasu; 06-22-2012 at 04:30 PM. Reason: replaced onion with opinion
Old 06-22-2012, 07:03 PM   #9
Chris
Administrator
Likes Given: 42
Makes sense. I don't like the rubber ones myself. We use clay on clay or SDR saddle wye out here and as they are not as smooth a transition as one would like they are proven to work (I think). We have thousands of them buried around here.
Chris is offline
Old 06-26-2012, 02:03 AM   #10
baird1971
@ John20 I don't think you are being more cautious than you should be, it just sounds like are a professional. One that doesn't just fix the problem but always thinks about the next Guy after you and what might happen. Like with the rubber fitting and sewer snake. If someone used that fitting and did break it and never knew it, than that waste can contaminate ground water and depends were you live it can cause harm.
People really don't know what a plumber is, they think that we just install pipes and different systems. But we are doing one of the most important jobs there is. We are responsible for the health and safety to the public and don't anybody forget that. Without plumbers there would be more disease and famine in the world. So keep up the good work guys LOL
baird1971 is offline
Two Shower heads - 1/2" Pipe jswerland General Plumbing Help 1 11-11-2011 11:26 PM
Connecting 3" ABS pipe into 3" Cast Iron hub oakumboakum General Plumbing Help 1 09-12-2011 02:02 AM
Tapping well line, worried about pressure... twoskinsoneman General Plumbing Help 19 06-03-2011 01:12 PM
Copper Pipe in my house 1/2" OD and 5/8" OD tom12l General Plumbing Help 2 05-09-2011 02:06 PM
