Piece of cake. I'm more afraid of digging the ditch than sweating copper
Clean the pipe and fittings thoroughly with emery cloth on the pipe, brush the fitting, slather some flux on the inside of the female and outside of the male, connect, heat, apply solder.
In 99% of residential pipe sizes, heat only needs to be applied to one side of the pipe. Heat rises, so point the torch at the bottom side of the connection.
Apply the solder to the opposite side of the heated side. the solder will "pull" its way around and seal the fitting.
Wipe excess flux and move to the next one.
Mapp gas is preferred.
http://i.ehow.com/images/GlobalPhoto/Articles/5495871/IMGA0652-main_Full.jpg
