Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Sump Pump Question
Old 11-06-2013, 02:49 PM   #1
johnnyfever
Default Sump Pump Question
Hello, I was planning on buying a battery powered back-up sump pump in case of power failure. A few days ago, we lost power for about 10 hours, and the water level in the pit only came up so far and stopped. So, my basement did not flood. Is there some type of overflow built into the under-foundation drainage system? Thanks to all who can offer any input into my question! Johnnyfever
johnnyfever is offline
Old 11-08-2013, 03:05 AM   #2
Mr_David
Liked 9 Times on 8 Posts
could be the water level stopped rising because that was the level of the ground water.
Mr_David is offline
Old 11-10-2013, 04:44 AM   #3
uplumb
There is no overflow built in.. where would it flow to? If it did flow somewhere, why would you need a sump pump? I hope the laws of gravity haven't changed on me again..
uplumb is offline
Sump Pump Help!!! EcclesCatia Pumps and Wells 2 09-06-2013 01:17 PM
Sump Pump in garage enough? commanche General Plumbing Help 1 02-27-2012 08:26 PM
Sump Pump Issue, HELP PLEASE! bnicol82 Pumps and Wells 2 08-07-2011 06:06 PM
Sump pump help snydaze General Plumbing Help 1 03-10-2011 02:16 AM
Sump Pump Septik Pumps and Wells 0 09-26-2010 03:33 PM
