Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Sulfer and black growth in toilet.
Old 06-05-2013, 08:28 AM   #1
GordonA
Default Sulfer and black growth in toilet.
Hello all. So I am on city water and the only place this happens is in the back bathroom and only in the one toilet. The shower and sink back there don't have that smell nor anywhere in the house. I have replaced the wax on the toilet twice.
It seems to only happen in the winter and clears up in the summer.
Can you explain why and how to fix it?
Thanks
GordonA is offline
Old 06-05-2013, 02:13 PM   #2
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
City water usually has chlorinated water. If you don't use those fixtures very often, bacteria can start growing once the chlorine dissipates in those lines. Friends of ours had a Townhome that was on the end of the line water wise. They had the odor quite often especially in the unused bathroom. (The one I used when visiting) The water there always stunk until it ran for a few minutes.
speedbump is offline
Old 06-06-2013, 08:47 PM   #3
Retroloco-LJ
Likes Given: 2
Thanks
The growth seems like an accumulation of bacteria. Try a bleach powered tablet drop in the back of your tank (Clorox or other similar brand) to see if that helps with the problem at all.
Smile. Don't worry. Life is awesome.
http://fhfurr.com
Retroloco-LJ is offline
Old 06-06-2013, 09:24 PM   #4
Liked 178 Times on 146 Posts
Likes Given: 130
I'm not a fan of chlorine bleach tablets in the toilet tank. They will shorten the life of the toilet inner parts (all parts). Had a service call where the home flooded from a broken fill valve - the chlorine tablets weaken the plastic fill valve and the fill valve broken apart.
2
People Like This
Old 06-06-2013, 09:30 PM   #5
Likes Given: 130
The black growth could be mold from too much heat and/or high humidity (notice you said it only happens in the winter). Do you run a humidifer in the winter ? Do the toilet set in a open bathroom or in a room in the bathroom ?
Old 06-06-2013, 11:29 PM   #6
Liked 391 Times on 328 Posts
Likes Given: 556
Another vote AGAINST chlorine tablets in the toilet tank.
2
People Like This
Old 06-07-2013, 12:05 AM   #7
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
I will third that vote against chlorine tablets. So hard on the toilet parts
IFIXH20 Likes This
Old 06-07-2013, 12:42 AM   #8
Not just hard on the toilets it's also hard on the plumber. The worst is the blue jelly things they throw into the tanks. Get that blue stuff on your hands and it there for a few day's.
2
People Like This
Black PVC, or ABS? cactuscake General Plumbing Help 4 09-22-2012 10:04 PM
Black polybutylene? phishfood General Plumbing Help 2 01-29-2012 12:04 PM
Black particles in water tazfan Pumps and Wells 21 12-31-2011 07:08 AM
Black Water Beeston Pumps and Wells 5 08-18-2011 02:07 PM
RV black water overflow wp630 Drain and Sewer Cleaning 5 03-10-2010 06:43 AM
