Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Stuck and leaking Outdoor faucet
Old 06-22-2011, 01:56 PM   #1
notalotofinfo
Default Stuck and leaking Outdoor faucet
Outside Faucet needs packing replaced but i cannot get the handle off. The nut comes loose and I have pull the screw out but I am not able to get the valve off. Help!!
notalotofinfo is offline
Old 06-22-2011, 11:52 PM   #2
Liked 192 Times on 138 Posts
Likes Given: 112
Spray with PB Blaster...not WD-40....let soak for 15 minutes, repeat. Then try to wiggle it loose then remove. Don't be surprised if the handle breaks, it seems like a simple task, but not always easy. Good luck.
Old 06-22-2011, 11:57 PM   #3
Second2None
Go get one of these.
Superior Tool 03870 Faucet Handle Puller Removes
Second2None is offline
Stuck faucet valve steam has no hex/packing nuts? leemort Showers and Tubs 6 06-07-2013 03:38 AM
Faucet Handle Difficult to Turn, now Stuck lmark103 Toilets and Sinks 1 07-01-2012 12:03 PM
Outdoor shower valve leaking bdgood General Plumbing Help 4 06-13-2012 04:57 PM
Outdoor faucet question clem General Plumbing Help 2 03-24-2012 02:55 AM
Leaking outdoor faucet sameguy General Plumbing Help 5 07-08-2010 03:02 PM
