Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Shut off valve
Old 12-12-2012, 09:17 PM   #1
bggas400
Default Shut off valve
Hi all... Can anyone tell from this picture, which valve I can turn to shut off the water? I don't care bout the baseboard heating. Just wanna drain the hot/cold water lines without turning off the main.
Thanks,
Barry
bggas400 is offline
Old 12-12-2012, 10:02 PM   #2
The red handled ball valve above the tempering valve.
johnjh2o is online now
Old 12-12-2012, 11:20 PM   #3
Beni
Liked 15 Times on 14 Posts
My vote is the yellow handle valve above the mixing valve. That is assuming the cold water continues to the boiler/ water heater.
Beni is offline
Old 12-12-2012, 11:54 PM   #4
That is the hot out of the heater. It looks like it's coming from the bottom of the heater. The cold water inlet is on the top.
Old 12-13-2012, 01:26 AM   #5
bggas400
Not sure what a tempering valve is. The black pipe going across the top is the cold water I believe. the other one coming down states 'hot pottable'. so if I shut off those two, I should be all set. Yes?
Barry
bggas400 is offline
Old 12-13-2012, 02:09 AM   #6
Liked 419 Times on 350 Posts
Likes Given: 62
Black pipe= gas normally.
Old 12-13-2012, 02:13 AM   #7
You may be in over your head if you can't tell the difference between a gas line and a water line.
Old 12-13-2012, 02:59 AM   #8
bggas400
There's no gas lines coming into this house.
bggas400 is offline
Old 12-13-2012, 06:28 PM   #9
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
The "black" one is copper I believe, the one with arrow? In my experience usually the darker colored copper lines are cold. Without being there its kinda hard to tell you exactly which valves. But only thing you can do is try. Shut them and see if the water is off
Old 12-14-2012, 12:22 AM   #10
Beni
Hum, well the other side of the tempering valve is coming from the boiler outlet (labeled) which leads me to believe that its the hot side. Hot water generally does not come from the bottom of a water heater or boiler.
All of the tempering valves I've seen has the hot and cold feeding left and right with the tempered water line out the bottom / top.
Beni is offline
moen shower valve won't shut off dburns Showers and Tubs 8 05-28-2012 05:36 PM
Water shooting out from shut off valve clunt22 General Plumbing Help 3 03-13-2012 11:14 PM
Help: Replace Main Shut Off Valve CWC General Plumbing Help 3 04-13-2011 06:30 PM
Washer Shut Off Valve ericakoe General Plumbing Help 4 09-15-2010 07:10 PM
Shut off valve sjc67 General Plumbing Help 5 02-21-2010 12:30 PM
