Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Shower mixing valve piping
Old 12-18-2013, 12:06 PM   #1
Jayman
Default Shower mixing valve piping
During my remodel I uncovered the shower wall with the existing mixing valve. As you can see in the picture the line entering the valve on the right tee's off and jumps from 1/2 to 3/4" or 1" goes up about a foot and then is capped off. Is there a reason for this? My first thought was that the contractor didn't have a 1/2" elbow and then just stuck this in the arrangement?
Jayman is offline
Old 12-18-2013, 01:25 PM   #2
Likes Given: 218
That is a hammer arrester. What I don't understand is why there isn't one on the hot.
Old 12-18-2013, 02:13 PM   #3
Jayman
I am installing a modern thermostatic mixing valve to replace this one. Its an externally mounted mixer i.e. not in the wall. Would it be appropriate to install this way on both the hot and the cold? Thank you
Jayman is offline
Old 12-19-2013, 12:10 AM   #4
Liked 385 Times on 325 Posts
Likes Given: 550
No, those field manufactured shock arrestors don't do any good after awhile. The air above the water is slowly absorbed into the pressurized water. If you want to install shock arrestors, buy the factory made ones with piston seals that have a gas charge in them.
Looking at Honeywell mixing valve PDubs Water Heaters and Softeners 17 01-24-2012 03:41 AM
Mixing valve not getting hot enough Web64 Showers and Tubs 1 12-05-2011 05:56 PM
ID a Shower mixing valve? logdy General Plumbing Help 1 08-05-2011 11:52 AM
Mixing Valve question warrenbrown General Plumbing Help 3 05-03-2011 10:38 PM
installing shower mixing valve and knob stevespens Showers and Tubs 2 02-03-2011 05:32 PM
