Yes, the problem is being caused by a bad tubspout.
They come in two general flavors. One type is held in place by a set screw and sealed by an O-ring. To remove this type, you need to loosen the set screw with an Allen (hex) wrench, and then pull the spout away from the wall. The screw will be located on the bottom, right up against the tile wall. The other type threads onto an adaptor that is soldered onto a copper pipe. To remove this type, you will need to unthread it from the adaptor. Usually by sticking the handles of a pair of pliers into the discharge opening of the tubspout.
