Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Shower Cold Water
Old 10-03-2013, 03:03 PM   #1
jbez
Default Shower Cold Water
When the cold water is turned on in my shower; sometimes it flows normal, sometimes its hesitates then either flows normal or flows very slow, other times there is no flow at all. I replaced the stem and the shower head but the problem is still there. Any ideas? Is the pipe clogged?
jbez is offline
Old 10-03-2013, 03:18 PM   #2
What make faucet do you have? If you don't know the make then post a picture so we can identify it.
Old 10-03-2013, 03:55 PM   #3
jbez
It's a Price Pfister. 12H-2H/C
jbez is offline
Old 10-03-2013, 04:01 PM   #4
Did you replace the center stem along with the hot & cold stem?
Old 10-03-2013, 04:12 PM   #5
jbez
There is no center stem - as far as I know. This is a shower with two knobs and I replaced both stems.
jbez is offline
Old 10-03-2013, 05:14 PM   #6
Sorry I thought you had a three valve. Your problem may be that your using after market parts. I see the stems came from Danco. Many times there stems cause problems. Try a different manufacture.
Old 10-03-2013, 10:19 PM   #7
Liked 178 Times on 146 Posts
Likes Given: 130
You may have a piece of the bibb washer lodge inside the valve body. Removed the stems and look inside the valve body with a flash light. If you do not see anything inside the valve body flush the valve body out with the stems removed.
To flush the valve body turn the water on full bore for 2 to 3 sec a couple times while the stems are removed. Be sure to secure the shower so water does not splash/spray outside the shower or run back into the wall. You might want to install the escutcheon to help keep water from running back into the wall.
Two Cold Water Pipes at Shower and Tub zdman General Plumbing Help 5 04-13-2013 01:43 PM
water help, please!!! 1 cold shower to many crankbait09 Water Heaters and Softeners 3 01-10-2013 02:13 AM
Bath faucet water stays hot, but shower is cold sidegate General Plumbing Help 6 05-15-2012 05:24 AM
Shower: Hot and Cold Water Issue guitarman1956 Showers and Tubs 7 03-20-2012 03:53 AM
no hot water only cold in bathroom shower ArtOfShred87 General Plumbing Help 5 05-28-2011 11:47 PM
