Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > shower clunking when toilet flushed
Old 01-16-2011, 01:12 PM   #1
Default shower clunking when toilet flushed
Good Morning,
We have a new issue with our house. When we flush the toilet, the shower makes a clunking noise. With a bit of research it sound like our vent pipe could be clogged. We had about 30 inches of snow last week, the same day this started. Is it possible that snow in our vent pipe is clogging this? If so, is it harmful for this to be happening while we wait for it to melt? Or should we get someone up on the roof? If not, what else could be causing this?
Thanks so much for your help!
telegirl is offline
Old 01-19-2011, 07:52 PM   #2
NotAnotherRep's Avatar
You are probably right, If snow has blocked the vent pipe then a vacuum is being caused. when you flush the toilet you are releasing a large amount of water through a large pipe. this causes a back suction effect which will cause the water in the traps on sinks and showers if connected to the same pipe to be pulled with them. That's why a soil pipe has a vent. It's not a problem as long as the snow melts away, if you notice the any drainage smells coming up through the shower waste just make sure that you put water down the shower to top up the water in the trap after you flush the toilet.
NotAnotherRep is offline
Shower into toilet drain FLGSHP7 Toilets and Sinks 9 11-11-2012 07:51 AM
Low Pressure everywhere when toilet is flushed DrEvil General Plumbing Help 3 02-14-2012 10:39 PM
Toilet/Shower backup - out of ideas Nellspixia Drain and Sewer Cleaning 2 09-04-2011 02:30 PM
low shower pressure corrects when toilet flushed StinkoMan General Plumbing Help 4 08-04-2011 12:38 AM
Please help, shower leaking under toilet have tried everything! kinnz03 Showers and Tubs 2 06-14-2011 12:09 AM
