Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Sewer 3" Cleanout pipe, but plug is 1 3/4" Would like to convert
Old 12-09-2013, 11:46 PM   #1
thesolidman1
Default Sewer 3" Cleanout pipe, but plug is 1 3/4" Would like to convert
Hi, I have a sewer cleanout in my garage. It is a 3" pipe but the plug size is 1.75", it a appears to use an adapter or reducer. I would like to know if it's possible to remove the reducer and upgrade the opening to a larger size plug, so I could use a mainline snake with a root cutter. The cleanout is surrounded in concrete and pretty much flush, see pix.Thanks very much for any help!!
thesolidman1 is offline
Old 12-11-2013, 01:29 PM   #2
Mr_David
Liked 9 Times on 8 Posts
That is not a 3" pipe , but only a 2" you are looking at the hub of a lead joint fitting. Also not a clean out for the main line , to small. Probably just a lateral 2" line for a sink or laundry drain
Mr_David is offline
Old 12-11-2013, 03:11 PM   #3
thesolidman1
Hi, ok that makes sense as it is right behind the washing machine. Thank you very much for your help. So would this be OK to access the main sewer line with a snake? I was thinking of heating the pipe and removing the lead adapter, and then capping with an expandable rubber type. This would give enough room for a snake with a cutter. Thank you again!
Old 12-12-2013, 12:24 AM   #4
Liked 385 Times on 325 Posts
Likes Given: 555
What Mr. David is saying is that the fitting and pipe beyond the cleanout are only 2", so you won't gain anything by removing the cleanout adaptor.
Boiler loop circulator pump sizing for "equivalent length of pipe"? JohnDS General Plumbing Help 1 11-15-2013 04:28 AM
Convert toilet drain to 2" washer drain hydrostream Toilets and Sinks 2 11-10-2012 10:31 PM
Where To Find a 1/2" Plug - LHT ? abrogard General Plumbing Help 7 01-04-2012 07:42 PM
Connecting 3" ABS pipe into 3" Cast Iron hub oakumboakum General Plumbing Help 1 09-12-2011 02:02 AM
Delta Shower "Plug" popped out GiantSquid Showers and Tubs 5 06-21-2011 12:21 AM
