Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Sand coming out from tub drain...
Old 03-13-2011, 01:57 AM   #1
mikeawesome
Default Sand coming out from tub drain...
I had a clog in my bath tub so I used an auger down the drain but it wouldn't go down far enough. I then tried going through the overflow tube and that didn't work either so I blocked the overflow tube with a rag and used a plunger on the drain and what looks like sand came up through it.
as far as I know nobody, in the house had been putting sand down the drain.. can it be a broken pipe letting sand seep in?
mikeawesome is offline
Old 03-13-2011, 04:37 PM   #2
yny
yny's Avatar
I would think if that was the case you would notice an extra wet area, or an extra high water bill.
I don't know the answer for sure, but maybe it has to do something with the water heater.
I changed my anode rod and did a flush and you would not believe the crap that came out of my tank, now the water is clearer.
Section 608 Universal , Section 609, R 410 A cert , PM cert , IAQ cert , Green Cert
yny is offline
Old 03-14-2011, 04:56 AM   #3
SlowDrip
Plumbing Sales
SlowDrip's Avatar
It could indeed be crap coming from a degraded anode rod. It never hurts to check this anyways as they should be changed regularly.
SlowDrip is offline
Old 03-14-2011, 05:03 AM   #4
rfdevere
Banned
Send a message via Skype™ to rfdevere
Plumbing In London
Are you guys mad? blaming the anode in a HWS?
my simple advice mate if there is sand in your area and not soil (mud) then a broken pipe is most likely the cause - also consider in most countries they use sand to pack a bath in/ off the ground? spaces behind bath panels can harbor problems for ages!!!! let me know
rfdevere is offline
Sand coming into tub from pipes after replacing old pipes Dearly Showers and Tubs 4 01-15-2012 04:15 PM
Water coming up through the stub up? ericivins General Plumbing Help 6 10-13-2011 12:13 AM
Inline water heater - melts sand? leftheart Water Heaters and Softeners 4 01-06-2011 01:53 PM
Only Air Coming out of Hot Water deceived Water Heaters and Softeners 14 12-20-2010 01:45 AM
