Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Rubber Grommet needed
Old 06-22-2011, 10:26 PM   #1
Melvinsmellvin
Default Rubber Grommet needed
Hi. I want to add a new drain inlet to an existing sewage basin in my basement. This run will be added to to side of the basin under the basement floor. I plan to use either 1.5 or 2 inch pvc pipe, probably 2 inch. As I understand it, I need to cut a hole in the side and use some sort of a rubber grommet to make a gas and liquid tight seal, simply shoving the inlet pipe through said hole. Problem is my local big box store and hardware store have been unable to help me obtain such a grommet or whatever I need. Local plumbing wholesaler said go hire a plumber. Does anyone know where I can buy what I need on line so i can proceed with this DIY project. Again, the inlet will be on the sidewall of the basin. thanks
Melvinsmellvin is offline
Old 06-22-2011, 11:50 PM   #2
Second2None
Maybe this is what your looking for.
Multi-Tite Gaskets - RainHarvest Systems Online Store for Rainwater Collection, Filtering and Sustainable Re-use.
Second2None is offline
Old 06-23-2011, 02:17 AM   #3
Melvinsmellvin
thanks, Maybe so. I sent an email to them asking re appropriateness of use with sewage basin. Maybe they will respond tomorrow. Appreciate your suggestion. If anybody else knows of possible source please put your 2 cents in. thanks again.
Do I need any rubber washer with those connections? bwspot Showers and Tubs 4 05-29-2012 04:11 AM
Particles of rubber (from pressure tank) in water? Vincent Pumps and Wells 4 09-02-2011 05:50 PM
Copper to Rubber Piping RSVRMAN General Plumbing Help 16 03-09-2011 06:06 AM
Shower head still dripping after replacing seats and rubber gaskets billyboy General Plumbing Help 2 03-09-2011 02:59 AM
Air Gap Needed? ExMechanic Toilets and Sinks 4 12-24-2010 06:13 AM
