Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Retrofit Bathtub Drain Pipe
Old 09-20-2011, 12:35 AM   #1
KHC2157
Default Retrofit Bathtub Drain Pipe
I'm replacing my bathtub. The existing drain pipes for the tub are brass. Both, the overflow drain and bottom drain are pipes are adjustable with compression fittings. I had to cut out (with a grinder) the bottom drain pipe. I only had to cut the part that is extendable (the piece that actually connects to the tub). I need to replace this part but cant find a brass drain pipe for tubs. My question is, can I connect a PVC pipe to the brass pipe and use a compression fitting? Any help would be greatly appreciated.
KHC2157 is offline
Old 09-20-2011, 04:35 AM   #2
Mr_David
Liked 9 Times on 8 Posts
Like this?
They are called bathtub waste and overflow.
GOOGLE it
Mr_David is offline
Old 09-21-2011, 11:27 PM   #3
Liked 388 Times on 326 Posts
Likes Given: 556
It would require purchasing the entire waste and overflow that Mr. David mentioned, but I have seen brass tub drain waste and overflow kits in Home Depot (Lake Mary Home Depot to be exact) some years ago.
phishfood is online now
Bathtub Drain Disaster, Please Help! abbyhope Showers and Tubs 1 07-07-2012 01:59 AM
Water hammer arrester retrofit on washing machine valve? tkcali General Plumbing Help 5 05-25-2012 04:36 PM
Need help before taking off bathtub drain pipe YosemiteJack Drain and Sewer Cleaning 5 12-14-2011 11:09 AM
Bathtub to Shower, Drain HELP pwgsx Showers and Tubs 4 11-22-2010 02:06 AM
Bathtub drain problem bluemax01 General Plumbing Help 2 07-21-2010 10:24 AM
