Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Repair help for hole in copper drain caused by screw
Old 06-15-2013, 04:32 AM   #1
mikeyjjohn55
Liked 4 Times on 1 Posts
Default Repair help for hole in copper drain caused by screw
Dumb mistake by me again. I screwed up literally. Advice appreciated!
When installing drywall with screws I accidentally pierced a 1 1/4" copper drainpipe in the wall. The hole is about the size of a pencil lead. Is there a simple permanent repair? Is it possible to just solder over the hole? Would a clamp or marine epoxy work? Maybe the best solution is to cut the pipe and solder a sleeve in place but that also be the most work. What would you do? Thanks, Michael J
mikeyjjohn55 is offline
Old 06-15-2013, 04:46 AM   #2
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
I have seen plumbers solder pinholes. But extremely don't recommend it. Cut it out and put a repair coupling in it.
camaroderrick73 is offline
Old 06-15-2013, 04:47 AM   #3
camaroderrick73
The way I would think about it is what is temporary and what is permanent. A clamp or epoxy will fail. No doubt in my mind.
A proper copper joint will not.
Old 06-15-2013, 05:23 PM   #4
mikeyjjohn55
Thanks Cam, I agree that a coupling would be best but since this is a horizontal pipe that's fit into a 1 1/2 X 1 1/2 inch notch in a vertical 2 x4 I was hoping there might be a simple fix.
Old 06-15-2013, 10:41 PM   #5
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
Depending on your soldering skills and how tight of a of a spot it is you could get away with a zip coupling to properly go from copper to pvc/abs. Personally I've never saw a fernco or zip coupling leak that was properly installed, I've came across some pretty old ones. But totally depends on what you want to do. I personally never solder old copper drain lines and convert to pvc or abs instead.
Old 06-16-2013, 02:23 PM   #6
camaroderrick73
Sorry, what's a zip coupling? Maybe I use different terminology or I might learn something...
stevemachine Likes This
Old 06-16-2013, 02:25 PM   #7
camaroderrick73
You know what , I just went back and read the original post . For some reason I was thinking copper water not dwv. Sorry , put a fernco around it and call it a day.
Old 06-16-2013, 02:50 PM   #8
Liked 384 Times on 324 Posts
Likes Given: 549
If I could get some flex in the line to make it possible, I would cut out a thin slice and install a no hub coupling. If not, I would split a fernco rubber coupling, put the split on the far side from the screwhole, and stack up hose clamps the entire length of the coupling. It will never leak that way.
phishfood is online now
Old 06-16-2013, 04:37 PM   #9
stevemachine
Likes Given: 91
A zip coupling I believe is what you guys would call a no hub coupling i believe. They make them to go from 1 1/2 or 1 1/4 copper to 1 1/2 cast (pvc/abs) up here its just a company that makes them. Or a fernco works, I've used both but I prefer the zip coupling because it's designed for copper to cast and it's a little more secure.
http://www.rollee.com/component/virtuemart/?page=shop.browse&category_id=6
Old 06-16-2013, 06:28 PM   #10
Likes Given: 549
Those appear to be much the same as a Fernco ProFlex coupling. A no hub coupling is a lighter duty of the same style, and is not intended to be used when outer diameter size changes.
How to repair shower pan drain williet57 Showers and Tubs 1 11-23-2012 10:18 PM
Basement Drain Smell/Repair jpm6621 General Plumbing Help 17 10-02-2012 10:11 PM
How should i repair this cast irn drain leak? markcal02 General Plumbing Help 9 10-20-2011 08:53 AM
nothing for replacement flange to screw to keithpf Toilets and Sinks 8 06-20-2011 04:34 AM
Best Way to Repair Leak in 4" PVC Sewer Drain jfenn General Plumbing Help 8 08-21-2010 02:15 AM
