Old 01-24-2012, 12:54 AM   #1
Default rear exhaust toilet - changing wax
Hi - other than it is horizontal and not vertical, is there anything different in changing the wax for a rear exhaust toilet?
gravine is offline   Reply With Quote
Old 01-24-2012, 12:59 AM   #2
yes, quite different as there is NO WAX..
Old 01-24-2012, 01:28 AM   #3
Wow. There's a quick education. Do you know of any good how to sites for this one? Thanks for the reply
Old 01-24-2012, 01:29 AM   #4
That depends on whether it sits on the floor or if it's wall hung.
Old 01-24-2012, 01:58 AM   #5
Sits on the floor
Old 01-24-2012, 02:11 AM   #6
If the flange is at the correct depth and screwed to the wall then a std. wax seal would be fine.
Old 01-24-2012, 03:40 AM   #7
Rear discharge toilet, use a foam ring a Wax will wear out fast.
Old 01-24-2012, 11:53 AM   #8
Sorry Liquid I don't agree. As long as the flange is set properly and secured in place the toilet won't move, being supported by the floor. Movement of any toilet will cause a wax seal to fail. If the toilet was wall hung then there would be some movement because the toilet is actually supporting the weight of the user. In that case a foam gasket is required.
Old 01-24-2012, 11:39 PM   #9
I see what you are saying, and as you know I respect your opinion but my experiences with this are that its not the toilets movement that causes the seal to fail but rather the flow of the discharge. I have encountered this on a few occasions where the gnereal handyman on a commercial job has replaced a foam ring with a wax one ( for reasons never quite clear ) and have found that the lower side of the wax has worn away when I removed the toilet. the upper half was unnafected. after only a month and a half one toilet was leaking badly andother only slightly, and upon removal of the third it was close to becomeing a leak.... these WERE all wall mount toilets mind you.
these are my experiences and the reason I would only install foam on a reaar discharge, but you have had other experiences, and likely more experience So I'll not doubt your knowledge on this.
I would be curious if the OP does go the Wax route to hear a progress report a few months later.
