Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > pressure tank issues
Old 05-21-2013, 05:24 PM   #1
Truelight
Default pressure tank issues
Facts: low pressure 20 psi. We had water logged pressure tank. Changed tank. Water has not gone into tank. Still only 20 psi. Did not install check valve. We have a submersible pump. If I turn off power to pump pressure holds at 20. If I leave power on but close the shut off valve after guage, pressure stays at 20. Do you have any ideas? Should I have put in a check valve? Thanks
Truelight is offline
Old 05-21-2013, 07:49 PM   #2
Likes Given: 218
I don't understand your statement that the water has not gone into the tank. Is it that the pressure won't build beyond 20 psi? Or is it going above 20 psi then drop after the pump turns off.
johnjh2o is online now
Old 05-21-2013, 08:39 PM   #3
Truelight
I can lift the tank easily so I know there is no water in it. Pressure does not go above 20
Old 05-21-2013, 10:20 PM   #4
Likes Given: 218
For some reason your pump isn't pumping. Is the pressure switch working? Check to see if you have power on the pump side of the switch.
Old 05-21-2013, 11:38 PM   #5
Truelight
The pump runs continually because it never goes above 20 psi
Old 05-21-2013, 11:41 PM   #6
Likes Given: 218
If the pump is running then you have a pump problem or a major leak in the line between the pump and the tank.
Old 05-21-2013, 11:54 PM   #7
RichardHilliard
RichardHilliard's Avatar
Liked 9 Times on 8 Posts
Likes Given: 2
What is your voltage?
The tank ,did you purchase a pressure tank or a galvanized tank? If you have a pressure tank make sure that the air in the bladder is 2 pounds less then the cut in pressure.
Check for leaks most likely in the casing
I had a hole in my pocket, I guess that is where my plans fell through.
Do not let "I've always done it this way" stop you
RichardHilliard is offline
Old 05-22-2013, 04:49 PM   #8
Truelight
Ok i think I might have a leak between my
well pump and house. At the well house I have
2 faucets, 1 on either side of what I think is a
check valve. In my basement I have a shut off.
My pump runs continually at 20 psi. How can I
test to see if there is a leak?
Old 05-22-2013, 09:38 PM   #9
RichardHilliard
Likes Given: 2
Turn power off to the pump pressure maintains 20 pounds= no leak or a bad gauge. If there is a leak between the pump and pressure tank it will go to zero pounds. Leak after house shutoff the pump should be able to pump up to 40 pounds or whatever your cutoff point is set.
240 volt submersible pump will not pump up to cutoff pressure if there is less than 240 /220 volts. Check your voltage to make sure you have 220/240 volts. Check your pressure switch too.
A pressure tank with bladder will only hold between 7-10 gallons of water. Your galvanized tank was a holding tank and not a pressure tank.
This may be the time to bring in an experienced plumber to test things for you.
It is extremely difficult to learn pumps on a forum. When it takes years to learn
Pressure tank issue Help jterry Pumps and Wells 8 03-05-2013 12:33 PM
Pressure Tank kmarine0120 Pumps and Wells 2 02-03-2013 06:10 PM
Issue w/ well pump, pressure tank or pressure switch??? pmoney1983 Pumps and Wells 2 10-27-2012 01:48 PM
Will Increasing Pressure Tank Size, Increase Pressure? GB Pumps and Wells 8 07-13-2012 05:18 AM
pressure tank ebeveridge Pumps and Wells 5 07-13-2011 03:37 PM
