Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Plumbing for an Ice Machine
Old 07-24-2013, 04:43 PM   #1
squidbilly
Default Plumbing for an Ice Machine
Hello. My church recently purchased an air-cooled under-the-counter Manitowoc ice machine. In the cabinet slot where it is going to be installed (on the far end of the kitchen with its back against an exterior wall consisting of sheet rock/insulation/metal siding), we do have a water hookup available but do not have any drain to accommodate the gravity drain on the back of the machine (for ice melting in the storage bin).
We have thought about just piping a drain out the wall to the exterior of the church since it would be on the back side of the building. However, I don't really know the best way to do that. We would also like it to be where we could slide the machine out from the wall if needed for maintenance, etc. Also, we don't want bugs or other creatures getting in through the pipe. Is an air gap needed in the drainage? Any advice would be appreciated. Thank you.
squidbilly is offline
Old 07-24-2013, 06:00 PM   #2
Liked 419 Times on 350 Posts
Likes Given: 62
I have a commercial ice maker at my vacation home, but it came with a flexible 6' drain line to accommodate repair removal. This line is tied into a 3/4" PVC line, with an air gap, which drains to the side of the house.
If this is an inspected commercial job, don't be surprised if the inspectors demand a trapped floor drain for the water to discharge into.
Old 07-24-2013, 07:15 PM   #3
squidbilly
Thanks for your response.
We are out in rural MS, so we are not subject to code inspections or anything like that. Nevertheless, I would obviously like to do this so as to avoid future problems and ensure the safety of those using the ice it makes.
So, I could basically come out of the back of the machine with the necessary plumbing to an air gap ....below the air gap would be pipe that leads directly outside and empties behind the building? Do you have anything special on the pipe that empties outdoors? Have you had any problems thus far with your arrangement? Thanks again.
Old 07-24-2013, 07:27 PM   #4
Likes Given: 62
The discharge rate on my ice maker is only about 16 ounces a day. Have you considered a gravity discharge into your sink drain, if possible?
Old 07-24-2013, 07:44 PM   #5
squidbilly
The sink drain is probably 40 ft. from the ice machine.
Old 07-24-2013, 08:08 PM   #6
Liked 192 Times on 138 Posts
Likes Given: 112
I wouldn't rely on a condensate pump to handle any large volumes of water such as defrosting and cleaning an ice bin, but to avoid a large project a Little Giant pump may work for you for melt water. You can connect a vinyl tube to it, run it up vertically then horizontally until you get above a fixture and run the tubing down to the drain. The pump may fit below the drain allowing for an air gap as well as providing access when servicing the pump or ice machine.
Old 07-24-2013, 10:26 PM   #7
squidbilly
I was hoping to do something like the following if plausible:
1: Come out of ice machine and turn vertically down towards the floor (put a valve here so drainage line could be shut off if machine were to be pulled away from wall for maintenance/repair/cleaning)
2: Air gap approx. 2x the diameter of the pipe
3: Horizontal catch pipe (with P-trap) that runs through the wall to the exterior of the building
4: Once outside, turn pipe vertically down into buried 5 gallon bucket (bucket is 1/2 full with pea gravel and 6-8" pea gravel underneath).
This would prevent anything from getting through drainage pipe, would allow machine to be removed as it would not be rigidly plumbed in place, and would prevent any backups directly into the machine to avoid contamination of the ice/storage bin.
Old 07-24-2013, 10:33 PM   #8
Likes Given: 62
I was checking out the ice maker you are purchasing, and they come in two types. 1) Water cooled and 2) Air cooled. Do you know which machine you are purchasing?
Old 07-24-2013, 10:38 PM   #9
squidbilly
Air-cooled under-the-counter machine. We have already purchased it (Manitowoc UY-0190).
Old 07-24-2013, 11:25 PM   #10
Likes Given: 62
OK thanks.
I just confirmed with my bro in law who repairs ice machines, and he confirmed exactly what Cad had mentioned. It is called an electric condensate pan, should cost you about $90, and can be purchased at Grangers and many other places.
Add washing machine hookup away from plumbing riser in high-rise apartment neoteric5 General Plumbing Help 5 09-26-2012 12:49 PM
Washing machine sends plumbing all out of whack! MeKaDi87 General Plumbing Help 6 06-26-2011 05:57 PM
Washing machine plumbing nickb7 General Plumbing Help 10 07-28-2010 05:01 PM
Any of you guys take apart a washing machine? Chris General Plumbing Help 7 02-26-2010 06:26 PM
Loud Washing Machine? Conway General Plumbing Help 3 01-14-2010 06:47 PM
