Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Please help as to why these pipes are leaking slighly after turning on water
Old 08-02-2013, 05:49 AM   #1
Fusion916
Default Please help as to why these pipes are leaking slighly after turning on water
So I just replace the hose bibb and added a T connector my water service from the basement out to the front and for some reason I'm getting very slightly leaks from a few of these connectors. On the T, as you can see from the picture, the back part of the T is connected to the water line, the front part I connected a hose bib, and the bottom part I have a pipe going down that I am going to connect to my irrigation system tomorrow.
The pipe is galvanized steel and I connected each pipe by wrapping teflon tape and screwing them in tight with a pipe wrench.
Everything feels solid (doesn't move) and looks good to me, but slightly leaks (small drips every 10 seconds or so) are still occurring.
What could be the issue? Not enough teflon tape? Too much teflon tape? Not tight enough? Too tight?
Fusion916 is offline
Old 08-02-2013, 06:45 AM   #2
Christoph
Christoph's Avatar
Liked 5 Times on 4 Posts
I like to use Teflon, pipe dope, and tighten them nice and tight with a couple of pipe wrenches.
Christoph is offline
phishfood Likes This
Old 08-02-2013, 10:48 AM   #3
Liked 335 Times on 273 Posts
Not tight enough. If that doesn't work retape the joint and also use pipe dope over the tape.
Old 08-02-2013, 04:45 PM   #4
Fusion916
I only have 1 pipe wrench so I couldn't tighten it super tight, I guess I'll buy that and some pipe dope today and redo these joints.
So it's teflon tape -> pipe dope over teflon tape -> tighten very tight with pipe trench? There is no such thing as too tight? No treat of cracking?
Also, how many loops of teflon tape do I need to wrap? is 4 good?
Old 08-02-2013, 05:00 PM   #5
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
4 should be good, ive never had a leak from too much teflon though. I like to use the pink T tape as its slightly thinker ( same stuff though ) and I wrap it 2-3 times. You NEED 2 pipe wrenches when working on pipe one for tightening and one for backup ( so the fitting doesnt turn on you ) there IS too tight and you will achieve this when the malleablle iron cracks ( dont go there ) remeber a 2 liter pop bottle holds 80 psi usually pretty easy and you dont crank the hell out of it. the threads on Black iron have a 30 degree taper that makes the primary seal, tape and dope are added means to be sure threads are good and imperfections in pipe thread and mating surfaces are compattiblle.
LiQuId is offline
Old 08-02-2013, 05:02 PM   #6
LiQuId
Likes Given: 20
also 2 pipe wrenches because you can imagine the can of worms you open up if you spin fittings IN the wall
LiQuId is offline
Old 08-02-2013, 05:07 PM   #7
Fusion916
Great thanks for the explanation. I know two pipe wrenches are better but I was trying to be cheap
So there is a such thing as too tight, any tips on how tight I can go without cracking the pipe?
Also, what brand is the pink teflon tape you use? Any particular brand of pipe dope you recommend?
Old 08-02-2013, 06:00 PM   #8
Liked 416 Times on 347 Posts
Likes Given: 62
Rectorseal #5, and leave the teflon tape in the drawer. it will lubricate, allowing a tighter seating, and has stop leak abilities.
Old 08-02-2013, 06:15 PM   #9
Fusion916
So you simply pour this liquid around the threads and tighten? That's it?
Old 08-02-2013, 11:55 PM   #10
Likes Given: 62
It has the consistency of toothpaste. Trust me, since I started using this stuff, I never use that cumbersome teflon tape.
Shower runs after turning off but only after some time passes howaboutme Showers and Tubs 9 01-07-2013 01:38 AM
Pump not turning off even after float switch replacement forwardlookguy Septic Tanks 9 10-14-2012 02:29 AM
why does toilet shut off no longer turning off? abfab General Plumbing Help 4 12-24-2011 03:39 AM
Rough in pipes leaking johnnymite General Plumbing Help 19 03-18-2011 11:37 AM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped Geejay Plumbing Products 1 03-01-2011 03:41 PM
