Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Pin hole leak in PEX cold water supply line
Old 12-17-2013, 07:18 PM   #1
kohlep0a
Default Pin hole leak in PEX cold water supply line
I have a mystery leak. It occurs in a cold water 1" PEX line that supplies water to our guest bathroom sink (I think). It has only occured once during a party for todders when that sink was running nearly constantly. Also, it's not at a junction. Its where the PEX is running through a talon clamp attached to a floor joist.
In the span of 4 hours, it dripped enough to create a 3 inch wet circle on the concrete floor.
Any ideas?
kohlep0a is offline
Old 12-17-2013, 11:40 PM   #2
Liked 391 Times on 328 Posts
Likes Given: 556
I have heard of one occasion, though not witnessed it myself, where PEX had rubbed against rough wood and abraded through in multiple spots.
Have you tried removing the pipe from the clamp and seeing if there are any wear marks on it?
Old 12-17-2013, 11:58 PM   #3
Liked 419 Times on 350 Posts
Likes Given: 62
Originally Posted by kohlep0a View Post
It has only occured once during a party for todders when that sink was running nearly constantly...
What you are saying is that this line normally does not leak, and only does so with continuous usage. Are you certain the leak is in the pex, or could the leak be higher, past the valve turning the water on?
johnjh2o Likes This
Old 12-18-2013, 03:09 PM   #4
kohlep0a
I do not believe that the leak is coming from anywhere up the line. The pipe is was dry on all sides leading to and from the drip. It does only leak with continuous usage.
I have considered just cutting the PEX and putting in a shark bite coupler, but it seems like I might be introducing more probability of leaks in the future. Thoughts?
kohlep0a is offline
Old 12-18-2013, 03:36 PM   #5
Likes Given: 62
I would still investigate further. Can you get the pex to leak by twisting or turning it? It may just be a soft crimp. Also, unless the Sharkbite is in an accessible location, most would recommend you do not use it.
HELP! Cannot detach water supply line jboggin General Plumbing Help 3 09-16-2012 05:15 PM
Horrible Taste--New Cold Water Supply Piping? arkitekton Plumbing Products 4 11-24-2011 02:28 AM
Different size hot water supply line Dempsey Water Heaters and Softeners 2 11-13-2011 03:16 AM
water line going from supply to drain?? Help? newhomeowner General Plumbing Help 10 01-02-2011 03:53 PM
New Water supply Line markus General Plumbing Help 2 08-28-2010 03:40 AM
