Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > P trap variations
Old 01-24-2011, 10:00 PM   #1
Kado
Default P trap variations
This has probably been discussed somewhere, but I could not find it... so here it goes (I apologize in advance for the elementary nature of the attached images):
I have three new vanities and one new tub to install but have space constraints for the traps that need to go in. The drain from the wall is just above the bottom shelf of the vanity - effectively making it impossible to place a standard trap without cutting the vanity. So the question is this, can a p-trap be installed above the wall drain and have two 90 degree (or 45 degree) elbows route the water down into it from the trap? See the attached image figure A for a better visual
Also, with respect to "p-traps", typically the drain goes straight down into the U part of the trap. Then the flow goes back up until it hits the 90 that sends the flow horizontal. Does it matter what angle that horizontal extension comes off the U portion of the trap? Can it go back over like a loop or is this a big "no-no" for some reason? I would love some explanation on this subject because one guy told me that it makes a difference whether the final bend in a P trap goes straight back vs left/right/over... I don't understand the physics of why that would make any difference, but maybe someone can shed some light on it for me. See figure B and C for a visual. I would like to use the "loop" option (figure C) for the tub trap. Does anyone see an issue with this?
If anyone can refer me to some technical literature, that would be helpful too.
Thanks in advance
Kado is offline
Old 01-24-2011, 10:45 PM   #2
Liked 392 Times on 328 Posts
Likes Given: 556
Figure A and B are against code, as the height difference between the outlet of the trap and the attachment to the vent is too great. This creates a situation known as an S-trap, and can cause the trap to siphon itself empty when the fixture drains.
There is no issue with Figure C that I am aware of, other than that it looks kind of funky. I have had to do the same thing many times, and have encountered no problems with it.
Old 01-25-2011, 11:39 AM   #3
Kado
Ok, Figure A & B are no good. I understand how they "could" syphon dry from a physics stand point, but there would need to be a lot of negative pressure for that to happen and the actual stack/soil vent is less than 2 feet away from those fixtures.
I've set both of those configurations up already because I did not want to destroy the furniture, nor did I want to open up the wall (which by the way would have required the exact same pipe bends but in the wall rather than out of the wall). Both have been extensively tested and no syphoning issues have been observed. However, for what it's worth, I would like to have everything up to code... so if there is a proper solution to match drain heights, I would love to know about it...any suggestions?
Kado is offline
Old 01-25-2011, 01:33 PM   #4
Mr_David
Liked 9 Times on 8 Posts
Open the wall and move the santee to where you want it.
You can raise it and move it left or right by turning the trap arm parallel to and in the wall with a 90 fitting coming out of wall where you want it.
You can change the direction of the trap arm with not more thanone 90 degree or two 45 degree fittings.
Mr_David is offline
Old 01-26-2011, 11:23 AM   #5
Kado
No dice on moving the "santee." The santee in the wall moves horizontal a few feet until it merges into the main stack/vent. So modifying that vertically would effectively create the same flow issue that I've created outside the wall. I mean, I don't know what the code says about that stuff... but to me that sounds like a "make work" project as I would still be faced with the same number of bends and changes in elevation in the piping after the modification.
Now you're saying the p trap arm direction can be changed with two 45 degree bends? So, in Figure A from the original post, if the GREEN and PURPLE sections of pipe were 45 degree bends then it would be okay? If that's true, then that method will get me to my objective. I've used 90 degree bends for now because that's what I have... but I can go pick up a few 45s to get it sorted out if that will put it into compliance.
Kado is offline
P-Trap in new vanity clinds30 General Plumbing Help 6 05-14-2011 06:55 PM
No trap in my shower Question123456 General Plumbing Help 2 12-29-2010 07:32 PM
P Trap Question... scotty General Plumbing Help 2 11-29-2010 11:32 AM
P trap too low lmbehlin8667 General Plumbing Help 1 09-30-2010 04:37 AM
Chrome Trap arm to ABS Trap? ChuckG General Plumbing Help 5 08-04-2010 10:03 PM
