Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > p trap with Nibco 4895
Old 12-23-2013, 07:27 PM   #1
elijawww
Default p trap with Nibco 4895
Hi, I am replacing my vanity, the sinks and top. The plumbing in this house is fairly new, 7 years old. It is 1 1/2" pvc, all glued. Since it is all glued I have to cut it off and start from the wall again.
I want to replace this P-trap with something that's easier to work with. I found Nibco 4895 is threaded, which means I can easily adjust, remove, clean it. Do i need to treat the treads with plumber's putty or teflon tape?
elijawww is offline
Old 12-24-2013, 01:22 AM   #2
Liked 391 Times on 328 Posts
Likes Given: 556
Take a look at the trap shown on this page. You will notice that the trap 90 degree fitting can be completely removed from the drain arm, making it much easier to snake out the line. Also, it can be moved in and out, making it very easy to align the Ptrap with the sink drain. http://www.oatey.com/brands/dearborn-brass/products/brass-plastic-and-commercial-tubular-grab-bars/plastic-p-traps/1-12-p-traps-w-threaded-adapter
phishfood is online now
jdc Likes This
Old 12-24-2013, 04:35 AM   #3
elijawww
All my ptrap looked like the one you showed me, when I lived in NC. But in MA it may not be allowed. I found some poster has commented:
"in massachusetts, it is illegal to have a slip joint on the outlet side of the trap. however,if the p-trap is not the removable type, it must have a clean out plug in the bottom."
Come to think of it, I don't think I have seen jbend style ptraps in local Lowes. Explains why all the rest of the bathrooms and kitchen is all glued.
Does that mean I have to replicate what I have now, but substitute glued trap portion with threaded? I can't find any info on what goes inside that joint, some compression washer, Teflon, putty, or it's self seating.
elijawww is offline
Old 12-27-2013, 03:35 AM   #4
kreemoweet
IMO using glued-up piping for undersink drains is just plain wacky. Plumber's union in Mass. probably has some pull in the legislature, I guess. Personally, I would ignore it (unless I was a pro plumber, of course). If it's like the similar PVC/ABS items I've dealt with, the union-joint trap from Nibco you linked to seals plastic-to-plastic, i.e. no washer, no goop, no nothing. In my experience they are not very reliable.
kreemoweet is offline
Old 12-27-2013, 11:22 PM   #5
elijawww
Thank you for the reply, kreemoweet will take your advice into account.
elijawww is offline
Trap under tub? bggas400 General Plumbing Help 15 12-08-2012 02:35 PM
P-Trap Issue scyalata General Plumbing Help 3 07-25-2012 02:19 PM
P trap variations Kado General Plumbing Help 4 01-26-2011 11:23 AM
P trap too low lmbehlin8667 General Plumbing Help 1 09-30-2010 04:37 AM
Chrome Trap arm to ABS Trap? ChuckG General Plumbing Help 5 08-04-2010 10:03 PM
