Old 08-23-2010, 06:11 PM   #1
Default odor from toilet
I have moved into a home that is about 10 years old and have lived in it for about a year now I have a upstairs bathroom toilet that has a odor eminating from it, I know that the toilet is lightly used and have never had a problem with this toilet before, However I do not know why this odor is ever so present and especially during these recent hot summer days we've been having, Iam thinking that maybe it may be a bad or worn wax ring, I havnt seen any leaking or water build up. can you help
sfloresfour is offline   Reply With Quote
Old 08-23-2010, 06:49 PM   #2
Is there water in the bowl to prevent gasses from escaping?
havasu is online now   Reply With Quote
Old 08-23-2010, 09:49 PM   #3
yes, the bowl is full it has never given me any problems until recent , This summer heat / maybe..
Old 08-23-2010, 09:57 PM   #4
Yeah, I'd pull the toilet and replace the wax ring. Also, check for prior seepage around the flange and clean and dry it before resetting.
Old 08-24-2010, 01:18 AM   #5
I agree. Pull the toilet and replace the wax seal. Since the only trap is in the toilet bowl, the odor is probably coming from a damaged seal below the toilet. Most toilets are installed as close as possible to the main vent, so all the smell passes by the toilet and the seal.
Old 08-30-2010, 04:32 PM   #6
thanks again fellas, your help and advise is really appreciated, Ill replace the wax ring.
Old 08-30-2010, 11:38 PM   #7
Is there a baseboard rad next to the toilet? I've seen a number of them that had dust in them and had been piddle splashed. They get a bit manky in humid weather.
Old 08-31-2010, 02:50 AM   #8
Well, that is a pleasant thought. Yuck!
Old 08-31-2010, 08:42 PM   #9
Then you'd love sanding, oil priming, and then painting them. BTDT way more often than I care to remember.
Old 09-21-2010, 05:01 PM   #10
just an update guys, NO more smell, thanks again for your help..........
defective wax ring, odors from toilet, sewer gas venting
