Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > New Plastic pipe
Old 04-21-2013, 11:51 AM   #1
melmar
Default New Plastic pipe
Hi
I recently employed a plumber to replace old copper pipe with new plastic.
I was very happy with the job until a person from a kitchen and bathroom fitters suggested that the job was not satisfactory and that right angled joints should have been used instead of bending the pipe. Please see picture.
Two pros are giving me opposite views who is right?
thanks
melmar is offline
Old 04-21-2013, 12:29 PM   #2
I would be more concerned with the drain lines. You have created a one of a kind S trap. Which will not pass any code and allow the trap to syphon.
Old 04-21-2013, 02:09 PM   #3
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
I agree with John, if the plumber could re pipe your house , he should told you your sink needed fixing by opening the wall an lowering the arm on the drain.
Now for the water, "rolling" pex is perfectly fine. My preference would be not having a another fitting that could leak.
camaroderrick73 is offline
phishfood Likes This
Old 04-22-2013, 12:37 AM   #4
Liked 192 Times on 138 Posts
Likes Given: 112
The straps on the plastic water lines are not an appropriate substitute for using a 90 degree fitting or a 90 degree bend support. Without a fitting or a bend support there is stress created at the fitting and is a leak risk.
I agree with John about the drains. It's not clear if he had also done the drain work since "copper pipe" could also include drain lines. I would have at least pointed it out for you and given you the option to have it repiped with the water lines as long as it didn't break your budget.
Old 04-22-2013, 08:23 PM   #5
melmar
Thanks for all the replys.
Going to get someone else in to look at the work.
melmar is offline
Cutting Plastic Pipe blitz Plumbing Tools and Equipment 21 06-01-2012 03:27 PM
Plumbers Putty on plastic index1489 General Plumbing Help 1 03-22-2012 01:26 PM
Siphon Effect with Plastic Water Tanks altmann General Plumbing Help 2 05-21-2010 02:32 AM
Toilet flush - plastic ball not rising sanbeach1 Toilets and Sinks 4 04-24-2010 01:48 PM
