Old 03-14-2010, 09:40 PM   #1
Default New p-trap leaking like a sieve....
Good afternoon folks. I am trying to install a new p-trap and am having trouble getting it water tight. I cut the old rusty end off of the chrome 1-1/4" pipe coming out of the wall. I then measured and cut the new trap and installed a 1-1/4" coupling that leaked horribly at the back nut that was over the old pipe. I then tried a rubber coupling with clamps and the same thing, it leaks as though nothing is there at the back side of the coupling....
Am I doing something wrong?
A few pics for you to see what I am talking about....
Thanks in advance for your time....
John W.
Indy
quadman is offline   Reply With Quote
Old 03-14-2010, 11:10 PM   #2
I believe your problem is due to the bent pipe coming out of the wall. Cut it at a point where it is perfectly round, and either re-apply your rubber sleeve or transfer to plastic with hand tightened compression nuts.
Old 03-22-2010, 12:27 PM   #3
If you can cut it back to a round piece it would be ideal, add a LIGHT lick of silicone inside the rubber before you put the rubber on
Darren Bosman
-Master Plumber-
www.plumbingthecape.co.za
P trap, leaking, chrome, compression
