Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Need help sourcing/fixing a part for showerhead
Old 04-22-2013, 06:08 PM   #1
eyc
Likes Given: 2
Default Need help sourcing/fixing a part for showerhead
Hi all – I’ve been pulling my hair out trying to source a broken part for my shower, and I was hoping the community could help me find it, or otherwise find a work-around.
I purchased a house with a pre-existing Hansgrohe setup, which, among other things, has a handheld shower head that rests on a vertical pipe in the shower. The showerhead looks like this:
The part that holds the showerhead to the pipe is broken beyond repair (plastic cracked). While the Clubmaster showerhead typically mounts into a fixed holder, the prior owner had mounted this one on a part that slides up and down the vertical pipe and articulates both laterally and vertically.
After hours or research and reviewing the parts manuals from Hansgrohe, I finally figured out that the piece I need is something only sold in the UK and is for a different model altogether:
Example dealer's page.
I’ve asked local Hansgrohe dealers if they have it, but they do not. It has been discontinued and they have none in stock. I’ve seen some alternatives out there, but none that articulate in the way this one does, which is critical based on the setup of this showerhead. The showerhead needs to articulate laterally and vertically, but I’m not too concerned about whether it slides up and down the pipe.
What’s the best way for me to find an alternative? What sorts of stores carry these things and how should I go about finding the proper replacement?
eyc is offline
Old 04-22-2013, 08:40 PM   #2
Liked 194 Times on 140 Posts
Likes Given: 112
You mentioned that you talked to local Hansgrohe dealers, but have you contacted the manufacturer's customer service directly? They should have more resources and be able to apply any warranty parts that are covered.
Telephone:
Customer Service: 1-800-334-0455
Technical Support: 1-800-334-0455
Marketing: 770-360-9880
Fax:
General Fax Number: 770-360-9887
Customer Service: 770-889-1783
Technical Support: 678-762-7042
Marketing: 770-667-1897
johnjh2o Likes This
Old 04-22-2013, 08:46 PM   #3
WilsonPlumbing
I would go strait to the manufacture.
Wilson Plumbing
832-475-4700
www.YourHoustonPlumber.com
WilsonPlumbing is offline
Old 04-23-2013, 01:26 AM   #4
eyc
Likes Given: 2
Telephone:
Fax:
Not sure why I didn't think of that. Thank you for the thought and the info. I'll try and let you know.
eyc is offline
Cant find replacement Kohler part... unsure how to proceed fixing leaky tub benhallbenhall Showers and Tubs 1 09-06-2012 10:46 PM
Leaking showerhead. Arclight52 Showers and Tubs 8 08-07-2012 03:07 AM
Modern Showerhead: Remove ball at end of arm? eyc General Plumbing Help 3 05-25-2012 04:04 PM
Check valves in showerhead LesF Showers and Tubs 3 03-14-2012 03:05 AM
Outdoor Showerhead Dilemma geosbride General Plumbing Help 1 09-12-2011 12:49 PM
