Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Need Advice
Old 09-26-2013, 02:58 PM   #1
StevenW1969
StevenW1969's Avatar
Default Need Advice
I have a renovation project that I have been working on and have to replace the sewer main pipe and all the interior plumbing. I got the main sewer pipe run it has a 1/2" drop per foot to the septic tank and have tried to keep this same drop throughout the rest of the drains. I attached some photo's of what I have so far. I know I will need a vent pipe for each drain since they will be more than 7-8 feet away from each other. I will use the same size vent as what the drain is so I don't get the gurgling sound when using one of them.
The advice I need is the junction where the sewer main comes into the home. I currently have a Ø4" 4 way and it just seems like this is wrong that the fitting I need should direct the flow of the waste towards the main line and not just to the main pipe as shown. I haven't glued anything together yet I wanted to test fit everything before I commit my components.
Any advice would be greatly appreciated.
StevenW1969 is offline
Old 09-26-2013, 04:20 PM   #2
Likes Given: 218
I don't have time to look it all over, but your using the wrong pipe under the floor it should all be sch 40 what you have is 3034. I will get back to you on the rest when I have more time.
Old 09-27-2013, 09:08 PM   #3
Haworthplumbing
Haworthplumbing's Avatar
Code in Canada will not let you use 90 bends on drainage unless it is a vent or carries waste from the horizontal to the vertical. 2 45 degree elbows are needed to do a 90. That cross tee is wrong. Do not use that. Use two y fittings with 45 elbows into them to make the turn. Tees are not permitted on their sides like that. Need to use y fittings.
Haworthplumbing is offline
Need Faucet Advice RossA Toilets and Sinks 17 08-27-2013 09:18 AM
Advice joedurky General Plumbing Help 1 04-01-2013 05:17 PM
VFD help/advice chaseme5 Pumps and Wells 5 11-30-2012 01:53 PM
Well advice requested havasu Pumps and Wells 21 05-11-2012 03:56 PM
Noises - looking for advice primer General Plumbing Help 8 03-25-2012 01:02 PM
