A variety of things could cause this, and most would require opening up walls to repair. Only thing it may be, and is fixable, is a clogged vent pipe. Drain lines need air to operate properly. The air is received from the vent pipe. If the pipe is clogged, the draining water pulls a vacuum in the line and causes the sound you hear. Could also be a pipe that is not secured in the wall and is moving when water is flowing.
Reason: Additional info
