Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Leak garage tap
Old 11-30-2013, 06:33 PM   #1
tilly
Default Leak garage tap
I have turned off the shut-off valve located under my sink for the outside tap in my garage. At first the shut off valve kept leaking around the packing nut but after I tightened as much as possible it finally stopped. Then I opened the outside faucet a little to drain out any water before weather gets cold. Days later it continues to drip a little, only 1 drop every 2 seconds though. Have gotten a man to try tightening the shut-off valve and it's as tight as it can go. Can I just close this outside faucet without worrying that this tiny bit of water will freeze in the pipes during the winter? It's about a 25 foot pipe running through my garage with an insulating sleeve on the pipe. Seems like very little water but just wondering if anyone has an opinion on whether or not this could cause a problem
tilly is offline
Old 11-30-2013, 07:16 PM   #2
No, even with a slow drip the line will eventually fill a freeze. You need to repair or replace the inside valve. Once repaired so it holds water turn the outside faucet on and keep it in that position until the warmer weather returns.
tilly Likes This
Old 11-30-2013, 09:39 PM   #3
tilly
Thanks John. Will repair/replace asap.
tilly is offline
How to add well line to garage? saiphes Pumps and Wells 2 11-27-2012 09:02 PM
Garage Retreat Chris General Discussion 9 05-25-2012 04:17 PM
Need to add faucet in garage beast696 General Plumbing Help 6 08-13-2010 11:05 PM
Total Garage Remodel BRad704 Project Display 26 04-16-2010 05:18 PM
Drain pit in the garage dry? memorex88 Drain and Sewer Cleaning 2 02-19-2010 02:38 PM
