Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Kitchen faucet/sink noises.
Old 08-21-2011, 03:48 PM   #1
andy31
Default Kitchen faucet/sink noises.
Hello,
I installed a new kitchen faucet (a Moen) the other day, and all went very smoothly. No leaks, it works great.
I have a dishwasher and a laundry machine (washer/dryer) in my kitchen, hooked up to my water lines beneath the kitchen sink. They've always been attached, even with my old faucet.
So...
1) When my washer/dryer and dishwasher go into certain modes, my new faucet rattles noisily, then stops. It rattles and sounds like a machine gun for a couple seconds.
2) My faucet isn't leaking or dripping anywhere, but my sink makes dripping sounds as if the faucet's dripping into it. I look into the drain with a flashlight, and I see water in there and, as I hear the drip, I see water (from somewhere) dripping into the water sitting in there. Don't know where this water's dripping from, but it's not the new faucet.
Any ideas on one or both of these noises?
Huge thanks,
Andy
andy31 is offline
Old 08-21-2011, 04:39 PM   #2
Mr_David
Liked 9 Times on 8 Posts
Make sure the stop valves under the sink are open all the way.
If you only partially open them, especially the hot which is probably a dual stop connected to both the sink and dishwasher, the washer could be vibrating as the water passes by it.
Mr_David is offline
Old 08-21-2011, 04:57 PM   #3
andy31
Thanks for your reply.
By "stop valves," do you mean that I should open the hot and cold water-intake knobs/valves (?) beneath the sink all the way? Currently, I have full pressure in my sink, but they're only open a turn and a half each, so I didn't think I needed to open them more.
Is there a disadvantage of opening these valves all the way (or a couple turns more)? Possible leakage somewhere?
Thank you.
andy31 is offline
Old 08-21-2011, 07:07 PM   #4
andy31
I opened the water-inlet valves another turn or so and ran a load of clothes in the W/D: no rattling/machine-gun sounds. Seems like that fixed it. THANKS! Now if only I could figure out that dripping sound in my kitchen sink....
Wonder if I need to replace or seal the sink basket.
andy31 is offline
Old 08-27-2011, 04:42 AM   #5
Mr_David
The stop valve under the sink should be full open then maybe turned back in one turn. Old stop valves may leak when you turn them. If they don't turn they aren't much use when you need them.
Glad to hear that it helped and that you came back to let us know.
Did you fix the leak/drip noise
Mr_David is offline
Old 08-27-2011, 02:02 PM   #6
Fansplumbing
Master Plumber
Sounds like the leak/drip noise could be your dishwasher line coming into your sink drain. Do you have a tailpiece with a drain pipe coming in from your dishwasher? Make sure the flexible line coming from the dishwasher is looped and and attached to the back of your cabinet about as high as you can get it. If this line isn't attached to the cabinet it could be holding water in it which would slowly (think drop by drop) drain back into the tailpiece.
Fansplumbing is offline
Old 08-27-2011, 02:07 PM   #7
andy31
Don't know if my stop valves are open fully minus one turn, but they're significantly more open than they'd been. Again, thanks.
I do, as a matter of fact, have a dishwasher connection, and it's not all that high. Not sure how water could drip from down (the bottom of the hose) to up (the sink drain where it's connected), especially when the dishwasher's not on, but you may have something there. I'll look to secure the peak of the hose as high as I can get it without straining it.
Thanks to you all,
Andy
andy31 is offline
Old 08-27-2011, 05:16 PM   #8
Mr_David
Some areas require an air gap on the dishwasher drain hose but if you don't have one the it is ussually required that it is installed as Fansplumbing had mentioned.
Do a google image search for dishwasher drain lines and air gaps. I'm sure there are plenty of pictures to look at.
Here's a couple examples
Mr_David is offline
Old 10-10-2012, 03:19 PM   #9
tigeorges0007
a leak/drip noise coming from my kitchen sink and no water is dripping anywhere? can you tell me why or is my reverse atmosis is acting?
tigeorges0007 is offline
Old 10-10-2012, 04:56 PM   #10
Liked 420 Times on 351 Posts
Likes Given: 62
From what I remember, R/O systems continually purge water so what you are hearing is normal. I'm sure in a bit, an expert in this field will give you more information.
Noises - looking for advice primer General Plumbing Help 8 03-25-2012 01:02 PM
Is there a better way to tie in the Kitchen Sink? flannag General Plumbing Help 16 01-08-2012 12:21 AM
looking for help with kitchen sink heebie Drain and Sewer Cleaning 5 07-25-2011 01:22 PM
Kitchen sink: hot water faucet not working kmillican Toilets and Sinks 2 01-18-2011 07:45 PM
Kitchen sink drains extremely slowly and backs up (double sink) TimeForAction General Plumbing Help 6 10-22-2010 07:46 AM
