Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Installing a new compression angle stop on to copper pipe.
Old 06-12-2013, 02:00 AM   #1
AQualityPlumber
Plumber
AQualityPlumber's Avatar
Liked 13 Times on 11 Posts
Default Installing a new compression angle stop on to copper pipe.
Replacing an old angle stop. First shut the water off to the building. Drain the system down the best you can by opening up lower fixtures. If this isn't possible, then keep a small bucket to catch the water. Pull the lav riser, aka supply line off the angle stop, then use 2 pairs of channel locks to untighten the compression nut. The nut and pharrel will not come off. Get your bucket ready to catch that water that might flow out. Now use a nut and pharrel puller to remove the nut and pharrel. Once you have it off, verify that the copper pipe is clean and not damaged. It's a good idea to use some sand cloth to clean it up. I always recommend to wipe a light amount of pipe thread sealant like megalock on the threads that the compression nut will thread on to. This isn't necessarily for sealing the threads because the brass pharrel should do that job, but this will help you get a nice tight crank and prevent the nut from ceasing up in the future. Once you have replaced the stop reinstall the lav riser, turn the water back on and test it for leaks. If none, life is good and you did the job right. If you see a drip, try to crank the nut a little more. If no luck then you may have to repeat this process to get a water tight seal. This has been a plumbing how to tip provided by A Quality Plumber Inc of Washington. Http://www.plumbingwa.com
A Quality Plumber Inc.
www.PlumbingWA.com
www.plumbingwa.blogspot.com
AQualityPlumber is offline
Old 06-12-2013, 02:05 AM   #2
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
Nut and ferrule remover? Never heard of it, do you have a link for one? I've been doing it the long way apparently
Old 06-12-2013, 02:12 AM   #3
AQualityPlumber
Plumber
You should be able to buy one at your local supply house. I know Ferguson and Pacific have them. If you don't know what it looks like, you may have to ask the desk clerk. Excuse the misspelled words. I'm using my phones auto word feature to type.
www.PlumbingWA.com
stevemachine Likes This
Old 06-12-2013, 02:14 AM   #4
AQualityPlumber
Plumber
It's to bad that this site does not have a plumbing how to section. I would have posted this article there.
www.PlumbingWA.com
Old 06-12-2013, 02:31 AM   #5
Steve, this is what they look like.
Old 06-12-2013, 03:56 AM   #6
stevemachine
Likes Given: 91
Awesome thanks guys. Do they work relatively well? I'll have to invest in one for sure
Old 06-12-2013, 04:49 AM   #7
AQualityPlumber
Plumber
It's a must have.
www.PlumbingWA.com
Old 06-12-2013, 10:43 AM   #8
Steve, I have never used one. They look like they should work. I have always used a hacksaw and just cut a slot in the compression ferrule then put a screwdriver into the slot and twisted it causing the ferrule to split.
Old 06-12-2013, 02:15 PM   #9
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
They work great! It takes short time versus cutting the ferrule. Less time equals more money!
camaroderrick73 is offline
Old 06-12-2013, 04:01 PM   #10
stevemachine
Likes Given: 91
That's much better. I'll have to find me on of those. Haven't saw one in a wholesaler up here yet but I'll start asking
Installing flexible copper pipe to water heater mcintoshmc General Plumbing Help 5 03-21-2013 01:21 AM
Creativity with Angle Stop Valve scalh001 General Plumbing Help 1 09-02-2012 11:56 AM
Copper/cpvc compression transition pita61 General Plumbing Help 6 10-27-2011 10:57 PM
Maximum Inlet Pipe Angle to Tank dengebre Septic Tanks 2 09-03-2011 02:38 PM
Copper Pipe Insulation Rob76 General Plumbing Help 3 04-07-2010 10:42 AM
