Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > How to seal rusted cleanout with broken bolts
Old 10-24-2013, 09:00 PM   #1
Pascal
Default How to seal rusted cleanout with broken bolts
Finally found the source of the smell in my basement. In a hole under the floor, accessible by removing a couple boards, I found an unsealed sewer cleanout. It had a rusted metal cover sitting on top of it held down by a pair of bricks. Looks like the original four bolts are snapped off and still in the holes in the flange. Any ideas on how to seal this? Preferably in a way I can open it in the future if needed. The white in the picture is the concrete foundation.
Pascal is offline
Old 10-24-2013, 11:25 PM   #2
Liked 178 Times on 146 Posts
Likes Given: 130
That looks like a old cast iron backwater valve with the flapper removed. How long have you been in your home - do you have problem with sewer stoppages- does your home sets lower that the city main sewer?
johnjh2o Likes This
Old 10-25-2013, 02:22 AM   #3
Pascal
Definitely cast iron. We've been here five years now and the only problem we've ever had with the sewer was the smell downstairs. No evidence of any overflow in this pit and I can view water etc. flowing through the pipe without a problem.
Pascal is offline
Old 10-26-2013, 01:23 PM   #4
Likes Given: 130
I would replace that backwater valve or cut it out and install a clean out , but you should have a plumber out who is familiar with your area before making any repairs/replacement. Although you haven't had any problems there could be the potential for problems.
LarryL Likes This
Need help removing rusted bolt on outdoor frost free faucet amodoko General Plumbing Help 6 05-31-2012 10:41 PM
Bolts tight put toilet is still lose matt2829 Toilets and Sinks 2 05-13-2012 01:40 AM
closet bolts turn freely OD354 Toilets and Sinks 6 06-16-2011 01:18 AM
Need help/advice on getting rusted expansion tank off pipe wem1472 Water Heaters and Softeners 2 04-08-2011 11:54 PM
Rusted out Flange Conway Toilets and Sinks 3 01-06-2010 09:10 PM
