Old 11-20-2011, 10:51 PM   #1
Default How to seal or cap a shower drain.
So I've removed a stand up shower and plan on replacing it with a closet. I have an open drain pipe in the floor that needs to be sealed. From my readings I've concluded that proper sealing is required in order to avoid unwanted odors.
Question: what's the "by the book" process of sealing off/capping a shower drain pipe?
Thank you
Kshelley41 is offline   Reply With Quote
Old 11-20-2011, 11:22 PM   #2
Cap it. Can't tell you how with out knowing the type pipe you have.
Old 11-20-2011, 11:30 PM   #3
It's a white rigid plastic drain pipe.
Old 11-20-2011, 11:46 PM   #4
Use a cap intended for pressure use, and solvent cement it onto the pipe. Most showers drains are a 2"
