Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > How does one connect ABS to other pipes
Old 11-13-2013, 06:52 PM   #1
djdenali
Default How does one connect ABS to other pipes
G'day,
New to the forum and new to plumbing. I am trying to hook up an outdoor sink that has white drain pipes--not quite PVC--that will be connected to ABS that then has to be tied into another ABS pipe.
Do I need primer AND ABS cement for the white pipe to ABS? And how about primer for the ABS to ABS? Or can I just use ABS cement for both of these connections?
thanks so much.
djdenali is offline
Old 11-13-2013, 07:26 PM   #2
ABS to ABS use ABS cement. ABS to PVC use a banded coupling.
phishfood Likes This
Old 11-13-2013, 07:29 PM   #3
djdenali
Thanks John,
But do I need Primer or any cleaning solvent with ABS to ABS? And the white pipe from the outdoor sink is not PVC proper. not sure exactly what it is. any additional thoughts?
djdenali is offline
Old 11-13-2013, 08:05 PM   #4
Primer is not needed with ABS.
Old 11-14-2013, 08:03 PM   #5
klee181438
Oatey also make ABS to PVC transitional glue that I've used before. It is only good on the transitioned fitting however. It comes in a small can with light green wording. Most Big box stores should carry it.
Atlanta, GA Plumber
Metro Septic and Plumbing
678-873-7934
http://www.metrosepticandplumbing.com
klee181438 is offline
Old 11-14-2013, 08:15 PM   #6
It's not approved by most building depts.
Old 11-15-2013, 11:14 AM   #7
plumber78
Liked 4 Times on 4 Posts
Likes Given: 6
Use a banded fitting. I would not suggest gluing PVC and ABS together even with that transitional glue.
plumber78 is offline
what is the order to connect the pipe q0987 General Plumbing Help 18 03-27-2013 03:22 AM
How to connect fittings to a fiberglass tank. Joelk General Plumbing Help 5 04-26-2012 12:46 AM
Quick-Connect adapters TheBus General Plumbing Help 1 10-29-2011 12:21 AM
Quick-Connect adapters TheBus General Plumbing Help 2 10-17-2011 10:38 PM
Can quick-connect fittings be reconnected? kotterr General Plumbing Help 4 07-14-2011 05:14 AM
