Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Hot water line cold and Cold water line hot!!!
Old 12-09-2013, 01:58 PM   #1
Duckworx
Default Hot water line cold and Cold water line hot!!!
Last winter I had a waterline freeze and bust during a bad ice storm. Once it thawed out, I cut and replaced it. After doing so all of my fixtures including toilets are reversed. How can I fix this problem????
Duckworx is offline
SamRam Likes This
Old 12-12-2013, 01:09 PM   #2
JohnDS
Liked 2 Times on 2 Posts
It sounds like in an attempt to repair the broken pipe, you hooked hot to cold and cold to hot. Turn off water supply to those pipes and change them back. Is this a serious question?
JohnDS is offline
SamRam Likes This
Old 12-12-2013, 06:40 PM   #3
johnduck0221
It was only one waterline that was frozen and fixed. I never unhooked any lines.
johnduck0221 is offline
Old 12-12-2013, 07:37 PM   #4
Liked 416 Times on 347 Posts
Likes Given: 61
Please elaborate more on what is happening, and whether you have a recirculation system. Is it all faucets or just a few? Help us to help you.
Old 12-14-2013, 02:34 PM   #5
johnduck0221
The lines that were frozen are the supply's to the washer. After these were repaired I turned my water back on. After a few days I noticed that the kitchen, hall bath supply's including the toilet were reversed. The washer and Masterbath are normal. Water is correct. I just know this has to be a simple fix but cannot for the life of me figure it out. No other water lines have been repaired.
Old 12-14-2013, 02:36 PM   #6
johnduck0221
I live in a 6yr old mobile home. Not sure if we have a re circulation system or not. If that helps
Old 12-14-2013, 02:41 PM   #7
JohnDS
How many lines did you repair? Now you are saying, "after these were repaired". It sounds like more than one. 1)Either you crossed the lines when repairing, 2)the hot and cold was always reversed and you are just noticing now, or 3)there is something you are not telling us. Seems odd.
JohnDS is offline
Old 12-14-2013, 02:56 PM   #8
johnduck0221
Hot and cold to washer... Guess I didn't specify that.. When I said only one I was referring to 1 location which was the washer area..
Old 12-14-2013, 03:23 PM   #9
Likes Given: 218
There a check valves built into clothes washers. One may have failed. If you don't turn the valves to the clothes washer off this may be the cause of your problem. Just turn off one of the valves feeding your washer and see if that helps.
2
People Like This
Old 12-15-2013, 02:07 PM   #10
johnduck0221
Where exactly are these check valves located on the washer? Can you send me a picture of what one may look like???
Water in bottom of heater tank - and - hot water in cold lines SteveRiley Water Heaters and Softeners 14 11-09-2012 12:17 AM
Leaking cold water line to washing machine Proac_fan General Plumbing Help 8 06-10-2012 06:48 PM
Removing cold water line andy867 Plumbing Tools and Equipment 5 04-29-2012 01:22 PM
Instant water heater - existing hot water line in - unit's hot line out to faucet Chuckiechan Water Heaters and Softeners 14 01-23-2012 05:40 PM
Hot water recirc pump installed, now hot water in cold lines? hevykevy420 General Plumbing Help 0 09-09-2010 03:35 PM
