Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > hot water copper supply pipe is noisy
Old 01-24-2013, 02:24 PM   #1
eagleslincoln
Default hot water copper supply pipe is noisy
Hot water supply and return pipes running from basement to second floor through the wall is very noisy. I am aware of the reason for the expansion of the copper pipe. As the pipe travels through the top and bottom plate studs in the wall, it is very noisy. What is the proper method of installing the copper pipe through the top and bottom plate studs. Should the holes be drilled much larger than the pipe itself? Is there some time of rubber piece to put around pipe through the stud. Please help, the noise is killing me!!!
eagleslincoln is offline
Old 01-24-2013, 02:30 PM   #2
Liked 121 Times on 106 Posts
Likes Given: 25
Most of the big box hardware stores carry a plastic sleeve that slides over the copper pipe and can be screwed to the studs and make the movement of pipes silent. And yes, the holes should be larger than the pipe going through the plates.
Old 01-24-2013, 06:13 PM   #3
eagleslincoln
Thanks for the quick response and will check my local hardware to correct the problem!
Can I/How-to Rebend Copper Pipe? elijf General Plumbing Help 2 05-24-2012 03:50 AM
What is this 2nd copper water pipe for? menudoboy General Plumbing Help 5 01-27-2012 07:04 AM
Loose Water Supply Pipe - should I worry? jebber45 Toilets and Sinks 12 05-13-2011 01:38 AM
Supply Manifold for Copper supplies? csutterer General Plumbing Help 3 02-02-2011 11:31 PM
Copper Pipe Insulation Rob76 General Plumbing Help 3 04-07-2010 10:42 AM
