Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > High and low pressure?
Old 06-27-2012, 10:39 PM   #1
Default High and low pressure?
I have 3 outside faucets. one off the kitchen, and one off each of the 2 bathrooms. Two have excellent water pressure, as does the house in general. One off the front bathroom has horrendous pressure. Back of the house faucet is very strong.
Any guesses anybody as far as whether this shows there to be a problem? Should this be approached by trying to clean or flush pipes?
TIA
Mike
mal37 is offline
Old 06-27-2012, 11:05 PM   #2
Liked 123 Times on 111 Posts
Likes Given: 71
Do you have a water softener? The one with the low pressure may be connected after the softener.
Old 06-27-2012, 11:21 PM   #3
Thanks for the response. No water softener, but there is one thing in that bathroom that's different.
There is a device in-between the waterline and the sink inline before the outside faucet. I was told it gets hot water hot faster? It plugs into an electric outlet that's live. Has a timer and a on/off/timer switch. no setting makes a difference. I don't believe this is inline anyway though. Just in-between the sink and the line on this part of the house.
mal37 is offline
Old 06-27-2012, 11:30 PM   #4
Likes Given: 71
Can you post a picture of it? It may be a re-circulating line.
Old 06-28-2012, 12:26 AM   #5
didn't seem to want to rotate. see if this works
mal37 is offline
Old 06-28-2012, 12:33 AM   #6
I don't understand why both hot and cold go in, but they go out to hot and cold on the faucet.
mal37 is offline
Old 06-28-2012, 01:05 AM   #7
Liked 103 Times on 93 Posts
Likes Given: 19
Yep, that is a recirc pump.
Old 06-28-2012, 01:25 AM   #8
would it have an effect on the water pressure for the outside faucet after the pump?
mal37 is offline
Old 06-28-2012, 01:31 AM   #9
i wonder if it's installed wrong. going to both hot and cold on the sink.
mal37 is offline
Old 06-28-2012, 01:40 AM   #10
Likes Given: 71
It's a re-circulating system that uses the cold water line to circulate the water. It should have no effect on your hose bib. I would start by turning the water off and remove the stem on the hose bib. There may be a loose washer in there that is restricting the flow.
high pressure in the morning konaka General Plumbing Help 5 12-13-2011 11:43 PM
High pressure hot water bluestang65 General Plumbing Help 18 11-26-2011 05:09 AM
Water pressure to high. Chris Lawn and Garden Irrigation 10 06-21-2011 04:34 PM
Help! High water pressure even after installing a thermal expantion tank. byoder7 General Plumbing Help 7 01-26-2011 03:22 PM
High pressure causing relief valve leak? gizmo Water Heaters and Softeners 3 04-09-2010 11:14 PM
