Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Help remove old faucet handles
Old 04-05-2013, 11:47 PM   #1
Kern
Kern's Avatar
Default Help remove old faucet handles
I need to remove my bathtub faucet handles in order to repair a leaky faucet. The cross handles are from the late 1930's and are likely American Standard. They do not have a set screw or a button cover on the front, just solid metal. Behind the handle is a nut, but it appears to be connected to the handle as one piece. Please see pictures. Any help would be greatly appreciated.
Kern is offline
Old 04-06-2013, 01:37 AM   #2
Loosen the nut behind the handle and the handle will pull off.
Old 04-07-2013, 02:35 PM   #3
Kern
Kern's Avatar
Thanks for the info. I was able to get the handle off! Unfortunately I broke the end of the stem in the process. Now I need to purchase a replacement stem, but I haven't had any luck finding a stem with a THREADED end instead of a splined end. Both the handle and nut thread onto the end of this stem. Has anyone seen this before, or know the manufacturer? Thanks for any insights on this one.
Kern is offline
Old 04-07-2013, 02:48 PM   #4
Liked 420 Times on 351 Posts
Likes Given: 62
Some of the experts here can easily identify a stem, provided you take a few pictures of it. Please post up a few pics and see if they can help you.
havasu is online now
Old 04-07-2013, 04:20 PM   #5
Kern
Kern's Avatar
This is the broken stem.
Kern is offline
Old 04-07-2013, 04:23 PM   #6
Kern
Kern's Avatar
This is the unbroken stem. It is 6 inches long. Thanks!
Kern is offline
Old 04-07-2013, 04:56 PM   #7
With the stem out you may find on one this site. Hope this helps.
http://www.kissler.com/Downloads/Stems.pdf
Replacing Handles & Faucet on Roman Tub mike81 Showers and Tubs 5 12-03-2012 10:13 PM
Can't remove a Moen T4570 faucet jeffobranch Toilets and Sinks 5 10-04-2012 05:04 PM
How to remove this faucet stem (PIC) draghi General Plumbing Help 5 08-05-2012 02:27 AM
Bathtub handles spin - replace handles or cartridges/stems? pmandra Showers and Tubs 3 02-25-2011 05:57 AM
Help! how to take off old Gopher tub Faucet handles catpace Showers and Tubs 2 05-03-2010 09:06 PM
