Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Help please
Old 01-07-2013, 10:34 PM   #1
Default Help please
Can anyone tell me if the configuraton in the attached pics is acceptable. My main concern was the "T" running horizontal off of the hot water inlet.
Everything is mocked up and ready to solder.
Thanks
Tileman is offline
Old 01-07-2013, 11:01 PM   #2
Liked 62 Times on 54 Posts
Likes Given: 15
That one tee on the hot is bull headed, assuming water comes up from the slab. It's not recommended to bull head tees, basically water comes from the slab and once it hits the tee it's forced to go both ways, whereas if you put a 90 where the tee is then tee off after the 90 water isn't being forced both ways. You can do it but its a better practice to not bull head your tees in any plumbing or gas. You could have future issues with getting a pin hole leak on the tee. Not saying it will just it could be a possibility.
Old 01-07-2013, 11:08 PM   #3
That's what I was afraid of. So the way I ran off of the cold water inlet will work?
Tileman is offline
Old 01-07-2013, 11:09 PM   #4
Liked 123 Times on 111 Posts
Likes Given: 70
If the lines are for the tub faucet it looks like the hot will be on the right instead of the left.
phishfood Likes This
Old 01-07-2013, 11:16 PM   #5
Likes Given: 15
I second that after taking another looking and yes Tileman it looks ok. I would try and level out the cold line if possible. But otherwise I think it looks good. Once you clean all your pipe and fittings you can fiddle around making it level, if its possible.
Old 01-08-2013, 01:48 AM   #6
Liked 66 Times on 56 Posts
Likes Given: 53
If you are going to keep those permalynx copper fitting (push fit fitting) , Place a wet rag over the push fit portion while soldering to help protect the o-ring.
Old 01-08-2013, 02:47 AM   #7
Likes Given: 15
That's what that fitting is! I've never seen those in my life
Old 01-08-2013, 02:34 PM   #8
The push fit fittings are a temporary cap.
Thanks for all of the help. You guys have a great forum.
Tileman is offline
