Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Help identifying a pipe coupling.
Old 02-05-2014, 08:55 PM   #1
rincer
Default Help identifying a pipe coupling.
Hi I am attaching a picture of a fire sprinkler system coupling that is leaking. A plumber came to look at it today and couldnt identify it. He said if he cant find it in their catalog back at the office they will have to cut the actual supply pipe and replace the whole joint. Which I would rather avoid doing.
So if anybody can identify that coupling and tell me where I can get a replacement, I would be very grateful!!
Thanks,
Paul.
rincer is offline
Old 02-10-2014, 08:17 AM   #2
jdc
Plumbing Technologist
jdc's Avatar
Liked 4 Times on 3 Posts
Likes Given: 2
That appears to be a Blazemaster CPVC sprinkler head adapter.
Looks to me like you're going to need to cut out the tee in order to replace the adapter. They do make a sprinkler head tee with metal thread insert. That might be the fitting for your application.
I'm not a sprinkler fitter, but hopefully the following link will steer you in the right direction.
http://www.vikinggroupinc.com/en/products/490/536
Good luck!
jdc is offline
identifying a specific vent-pipe on my roof MIKEMCD77 General Plumbing Help 2 12-29-2013 07:46 PM
Need help identifying what a pipe might be 45SSVaquero General Plumbing Help 0 11-10-2013 11:07 PM
Dresser coupling with galvanized pipe shnaig General Plumbing Help 0 05-01-2012 03:15 PM
cutting a flexible coupling bob_d General Plumbing Help 1 11-18-2011 12:20 PM
Sealing PVC coupling from inside drain dkohl Showers and Tubs 2 01-26-2011 01:15 AM
