Old 01-19-2012, 06:47 PM   #1
Default Help
My new tub will not reach the old drain connection due to the pad causing it to sit higher, is there a way fix this with out completely redoing the plumbing
Shirtail is offline   Reply With Quote
Old 01-19-2012, 09:03 PM   #2
It is very rare when replacing a tub that the drain will fit. You will have to redo it. It shouldn't that hard to do if you have good access to it.
Old 01-19-2012, 09:22 PM   #3
Thank you, it seems that I can hopefully just heat up and resolder it in the correct position.
Old 01-20-2012, 08:29 AM   #4
copper drains eh?
Are you confident with soldering ? and your measurement skills ?
not trying to be insulting, just asking so that you dont end up with frusteration and burnt stuff... this is a super Easy job for a plumber but might be more difficult for a homeowner or general handyman.
