Unless the company did a camera inspection, "guessing" that it is dirt is not a good thing to state. When a drain line is not used for an extended period of time, all the solids that are stuck to the pipe walls dry up and break loose. This could be the cause of any blockage. If the pipe was pitched properly when installed, solids should not be sitting in the line.
