Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Gray Pex?
Old 10-15-2012, 05:41 PM   #1
rquad
Default Gray Pex?
I'm looking at buying a house. It has brand-new plumbing throughout, but the pipes are gray. The pipe says "BOW 3/4" (CTS) Superflex 2110 SDR-11 100 PSI". I was scared off when I first saw this, thinking it was the cheap Quest stuff. With further study, I suspect it is Pex, but I've never seen or heard of gray Pex. And I do mean the pipes are gray - they are not white, off white, milky, or any other color like traditional white Pex. These pipes are the same exact color as cheap mobile home Quest.
Is this Pex?
rquad is offline
Old 10-15-2012, 07:59 PM   #2
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
Poly B, google it. That stuff is brutal. It's wrecked a lot of homes and now is banned. But some houses have it and its fine with no issues. Probably depends on how chlorinated you water is, Chlorine makes poly b brittle
Old 10-15-2012, 07:59 PM   #3
stevemachine
Likes Given: 91
Maybe post a pic to confirm but I bet its poly b
Old 10-15-2012, 08:37 PM   #4
reedplumber
reedplumber's Avatar
Never seen gray pex, seen gray poly pipe though, different monster, different fittings, it's what they use in trailer houses around here lol
reedplumber is offline
Old 10-15-2012, 10:31 PM   #5
Liked 416 Times on 347 Posts
Likes Given: 62
There was a multi-million $ settlement involving PB Pipe, but unfortunately the settlement is done and the money was spent. Lets hope that is not what it is.
Old 10-16-2012, 12:10 PM   #6
rquad
Here's a pic...
If it's new construction, how could it be Quest/PB? I thought they didn't make it any longer.
rquad is offline
Old 10-16-2012, 02:40 PM   #7
journeyman
Liked 16 Times on 15 Posts
That looks like quest to me. Either way plastic pipe is junk. It will always be a problem more so on the hot side due to expanding and contracting. Copper is also the best choice. But it is expensive to repipe a home. Hope everything works out. Always a good idea to turn water off to house especially if your gonna be gone for a long time. Better to catch a problem when some one is home rather then when someone is not.
journeyman is offline
Old 10-16-2012, 11:56 PM   #8
Liked 385 Times on 325 Posts
Likes Given: 555
Around here, I have seen homes with polybutylene piping outlasting copper piping. Central Florida seems to have a bad problem with copper piping developing pinhole leaks.
Not to say that PB is necessarily a better pipe than copper, it isn't. But quality of installation and matching the type of pipe to water conditions makes saying any one pipe is "best" all of the time rather difficult.
Old 10-17-2012, 12:01 AM   #9
Likes Given: 555
The only thing I found with a web search for that was a BOW PEX product, but it doesn't seem to be available in gray. If I had to guess, I would say PB.http://www.rundle-spence.com/index.jsp?path=product&part=1320419&ds=dept&proces s=search&qdx=0&ID=,Plumbing,Pipe.Valves.Fittings,P ipe,Pex.Tubing...BowPex
Old 10-17-2012, 01:35 AM   #10
reedplumber
Ok took me a minute lmao sorry I coulda answered this sooner, that's not pex or poly b pipe, it is a polyethylene pipe but its classification is actually sdr-11. Which actually is a differentiation of wall thickness, there's sdr-11, sdr-21, so on so forth sdr-15 those are just thickness schedules. Fittings on the other hand may be a booger. We use sdr-11 pipe ALOT for geothermal, so chances are its good pipe and won't have any problems with it for a long time. Like I said finding fittings may prove to be the tough part because all of the sdr-11 pipe and fittings we have done have all been butt or socket welded like gas poly.
Gray Water hardrock General Plumbing Help 2 12-11-2010 06:48 PM
